Results 1 to 2 of 2
    Jul 2014
    MY2008 Tora 302 Rebuild/Upgrade questions
    Hello all,
    First post here, I was having a little trouble getting a concrete answer to my questions through search and lurking.
    I have a MY 2008 Tora 302 solo air (it has a decal showing tora rs on it...) It is loooong over due for service and I am going to go old school and upgrade this thing vs get a new fork.
    I wanted to verify that the ARGYLE MoCo 11.4015.017.000 will work in the MY 2008 Tora since i haven't been able to figure out what the difference is with the 2009+ Tora.
    I have lost the rebound adjuster knob as well so i am looking to just replace the entire rebound shaft assy since i will be tearing it apart anyway. So does anyone know if either the Argyle rebound damper assembly 11.4015.257.000, or the HC3 08-10 Tora XC/SL/Race rebound damper assembly 11.4015.304.020 will work? I appears that they would from Rockshox spare parts cat. but would be nice to get confirmation.
    Lastly, I am planning on removing the travel spacer in the air spring side to bump travel to 130mm from 100mm, has anyone had any comments good/bad/indifferent on the increased travel with a hardtail (2008 Trek 6500)?
    I know there are new and greater things out there, but I am a tinkerer so I am really excited about doing this despite the fork not really being worth it.
    Any input.... beside buy an new fork... would be greatly appreciated!
    Jul 2014
    *bump*
    I know this is an old fork but someone out there has surely worked with these things??
  1. Tora lowers upgrade
    By phoenixnr in forum Shocks and Suspension
    Last Post: 10-25-2014, 05:41 AM
  2. Tora needing constant rebuild
    By Da Dook in forum Shocks and Suspension
    Last Post: 08-29-2013, 10:45 PM
  3. Tora 318 fork upgrade.. What to upgrade to?
    By chadalex78 in forum General Discussion
    Last Post: 02-08-2012, 08:42 PM
  4. RockShox Tora rebuild
    By steelpot in forum Shocks and Suspension
    Last Post: 12-22-2011, 12:59 PM
  5. Service/rebuild questions for a Tora
    By madsedan in forum Shocks and Suspension
    Last Post: 05-09-2011, 08:09 AM
