Results 1 to 5 of 5
    Nov 2008
    Bonking ... not feelin' well My old Fox float rp3 shock is different after service
    Hello everybody!
    I have old fox float rp3 shock (from around 2006).
    About few months I got it serviced. And now it is not supple to small bumps like it was before. It feels much firmer. Now, with propedal fully opened, it feels like it felted before with propedal in maximum position. I even pumped it to lower pressure then before.
    At first I thought that it is because of new seals, but after few months situation is not improved.
    Is it possible that, by mistake, they changed propedal settings and now I don't have fully open propedal?
    (I still feal difference between three propedal positions)
    bump and grind
    Reputation: cobym2's Avatar
    Apr 2005
    I have the exact same experIence. I switched temporarily to a basic cheapo shock and it feels better. Any solutions?
    What kind of service , air sleeve or more ?
    Feb 2010
    If it was a full rebuild (not just an air can service) then they may have upped the IFP pressure. RP3's initially came with relatively low IFP pressures, but in subsequent literature Fox specced higher IFP pressures.
    Alternatively, before it was serviced the IFP pressure may have been low which results in the shock having less platform. Now that the IFP pressure is back to the recommended setting the shock will have more platform.
    PMK
    PMK is offline
    Reputation: PMK's Avatar
    More likely the damper portion had air in the fluid. This is bad. When they serviced the damper, now the fluid has no air mixed with the oil and works properly.
    PK
    Reps! We don't need no stickin' reps!
  1. Fox Float 120RL Service
    By chuckie33 in forum Shocks and Suspension
    Last Post: 10-07-2010, 06:37 AM
  2. Fox Float after service question
    By dbd in forum Weight Weenies
    Last Post: 05-19-2010, 01:00 PM
  3. Fox Float after service question
    By dbd in forum XC Racing and Training
    Last Post: 05-18-2010, 01:27 PM
  4. Fox float DIY service ?
    By mzungo in forum Shocks and Suspension
    Last Post: 01-10-2007, 11:59 AM
  5. PUSH's Fox float shock service interval?
    By SingleTrackHound in forum Shocks and Suspension
    Last Post: 12-09-2005, 10:37 AM
