• 01-26-2013
    krt
    Movement of the shock on it's mounting points
    Hi.
    Yesterday I finally got my new Transition Covert frame.
    When I was building up the bike I noticed that when I lifted up the back wheel something was making a quiet 'click' sound. The sound was comming from the rear shock. It can move up and down (not side to side) on the top mounting point, the one on the down tube. The movement is very slight but it is noticeable. Is that normal?
  • 01-26-2013
    jkidd_39
    No. It should not move. Take it off and do some measuring would be your best bet.
  • 01-26-2013
    krt
    I thought so. I don't know what I can do about this. I took off the shock and the hole is slightely bigger then the 'bolt'. I can wiggle it slightely when it's in the shock. That's a problem with the shock then, isn't it?
  • 01-26-2013
    keen
    When you tighten the bolt it should "sandwich" the the frame's mounting tabs to the shock - larger hole size won't matter. Frame manufactures sometimes use proprietary bolts to mount their shocks could be missing a washer or ??? You could try a regular 8mm x ? and see if it tightens everything up. Really its a new frame I'd be making a call to Transition Bikes.
  • 01-26-2013
    kneecap
    I think krt's referring to slop in the upper shock bushing rather than the bike frame?
    If that's the case, the shock bushing is easily acquired from various internet bike stores, & easily replaceable with a couple sockets.
    I picked up one of mtberforlif'es tool a while back that comes w/a handful of bushings, works great, & you get some bushings as well...
  • 01-26-2013
    ehigh
    Sounds like a worn out AKA blown out bushing. When I've had a blown bushing on a shock, it makes that slight click when I lift the end of the bike. Typically a cheap fix.
    Not sure what you would base any measurement taking off of. Take it to a shop and they would probably confirm that it is the bushing.
    Sent from my Desire HD using Tapatalk 2
  • 01-26-2013
    keen
    yesterday I finally got my new Transition Covert frame.
    One would assume if a shock were included the new reducers would be fine. If there is enough play in used shock reducers, to cause movement, they would fall right out of the shock when removed.
  • 01-26-2013
    Mtn-Rider
    I had the exact same thing and with new lower shock mounts nothing changed. I looked at the bolt for wear and can't see anything that indicates it has worn down.
    The small gap between the bolt and reducers appears to be by design, maybe because it's a pivot point for the suspension which needs to allow frictionless rotation. If it where a perfect fit it would likely turn into one of those loved squeaky points on an FS frame.
  • 01-26-2013
    kneecap
    He says "the bolt wiggles in the shock". bushings generally do not fall outa shocks. They wear at the rotation point between the bolt & the inner side of the bushing.
    &, yeah, you'd think new parts shouldn't be a poor fit??
  • 01-28-2013
    trailbildr
    Brand new or new to you?
    It's your upper or lower DU bushing, most likely. Take your shock off, measure the ID, OD and length of the pieces pressed into your upper and lower shock mounts and order some steel replacements (get a few). You might need an arbor press to get them back in. If the bushings fall out of the shock, you'll know they were rocking. It may be the ID causing the problem.
    Harbor freight has cheap presses...
    mk
  • 01-28-2013
    krt
    The problem was that I hadn't tightened the bolts enough. I retightened them and the shock doesn't move anymore. I'll get a torque wrench and tighten the bolts to the specified torque in a couple of days.
  • 01-28-2013
    kneecap
    Yeah, Same thing happens to me occasionally, I'm an under-tightener, parts get loose, especially the shock.I assume that too tight bolts might reduce suspension action. Proper torque is the answer!
  • 01-28-2013
    mtnbiker4life
    Hi.
    I would put new DU/DP4 Bushings in the shock and get new RS 3-Piece reducers. :thumbsup:
