Results 1 to 6 of 6
    more precise shock pump?
    i have a relatively cheap shock pump, i think it works just fine but it would be nice if i could see the PSI in smaller increments. It goes up to 400 psi but i really only use it from about 120-130 (fox rp2). Making adjustments in a 10-15 psi range is somewhat guesswork at that scale. Its marked at every 10.
    I thought a 10 psi change was fairly noticeable but am i just getting too picky?
    Class Clown
    Reputation: dundundata's Avatar
    Is it like this? (Rebranded Giyo) I guess I see what you mean I can go in between the 10 mark but can't choose exactly say, 97psi although I'm sure I could come close. One thing I like about this pump is the release valve only let's out a tiny bit of air with each press so I can fine tune it pretty well. Would be interested in seeing what other people use.
    its made by a company called avenir
    I guess im just surprised for as precise and detailed most other elements of the bike are. 140 vs 150mm suspension, chainstay lengths, weight in grams, etc, etc. And here we are using comparatively imprecise gauges to tune the thing. And people love to say how getting your suspension *dialed* will make a huge difference.
    even the fox shock pump reads in 10 psi increments.
    They do make pumps with gauges with a smaller range, so you can see the increments better. I think mine goes to 300 psi, and is marked every 5 psi, so I can estimate the pressure within about +/- 1 psi of where I think it is, and that is fine for pressures in the ranges I deal with (130-170)
    OTOH, when I had a low pressure fork that ran pressure in the 30's, I needed a gauge with a much lower range.
    Save Jesus
    Reputation: beanbag's Avatar
    Buy a cheap shock pump where you can unscrew the gauge and add your own.
    XC Hack
    Dec 2011
    I have a Planet Bike ShockMate from REI--pretty basic for a pump. It's in 10 psi increments too but I've found that measuring my sag with a ruler is the only precise way. The gauge on mine exists only to get me in the same ballpark each time. I then adjust based on measuring with the ruler.
  1. shock pump vs regular pump??
    By Luckyr in forum Beginner's Corner
    Last Post: 10-22-2012, 01:05 PM
  2. Precise digital pressure gauge worth it?
    By DeanFBM in forum Shocks and Suspension
    Last Post: 09-29-2012, 10:17 AM
  3. What are you using to pump your air shock?
    By 2 Slow in forum Shocks and Suspension
    Last Post: 09-17-2012, 09:58 AM
  4. Floor pump as a shock pump?
    By AZGroundPound3r in forum Shocks and Suspension
    Last Post: 05-12-2012, 05:00 PM
  5. how precise does the hanger need to be
    By Dichotomous in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-09-2011, 10:42 AM
