Results 1 to 19 of 19
    Reputation: client_9's Avatar
    Mobil 1 5w-30 ...correct?
    Just to confirm ...
    This is what I want for Fox forks, right?
    aka dan51
    Reputation: d-bug's Avatar
    Mar 2005
    Only for lubricating lowers, not for the damper.
    Right, the lowers. thanks.
    Cut Casing Whisperer
    Reputation: Mr.P's Avatar
    Feb 2005
    Quote Originally Posted by client_9 View Post
    Just to confirm ...
    Or another brand synthetic 5w30 will work fine too.
    I've been using it for the last 5-6 years in the lowers and it's kept my 06 Nixon rockin!
    P
    Ok for RS as well?
    I assume that is Ok for a RS Reba as well (lowers of course).
    I have just been using the lightweight upper stuff up to now without any noticeable issues. My local bike shop does not carry the heavier lowers oil.
    Other question is must you use synthetic?
    Thanks,
    J
    Ok for RS as well?
    Thanks,
    J
    Former Bike Wrench
    Yes it works on Rock Shox forks.
    The reason for using Synthetic comes down to basic knowledge of motor oils. If you want all the details visit Bob Is The Oil Guy website. It basically comes down to the fact that Synthetic oil is going to provide better lubrication (especially at the much lower temperatures in bicycle forks) which means longer life for your fork bushings, considering the price difference is only a few $$ between conventional and synthetic motor oil it's a bargain.
    $7.99 @ Sears Automotive
    Save Jesus
    Reputation: beanbag's Avatar
    May I also suggest #2 way oil?
    Better clinging oil than Fox's red and green oil ?
    Edit: never mind, you already saw that thread.
    5w-20 works too. the viscosity is slightly lower than the 5w-30. 49 at 40C vs 61 at 40c. 49 typically corresponds to 10 to 15wt fork oil. 61 is 15 to 20wt. I'm not sure how the bath oil viscosity will change characteristics though, but it might have a little affect.
    Former Bike Wrench
    Quote Originally Posted by One Pivot View Post
    Yes, if your fork runs at 200f at a few thousand cycles per minute for hours on end, you MAY benefit from synthetic after 100,000 miles or so.
    Synthetic oil is all about resistance to heat breakdown.. which just doesnt happen on bikes. The "problem" with bikes is the ~10cc of oil they use that is usually factory underfilled, or leaks out during riding. Its important to have something in there. When they run empty, bad stuff happens.
    Well then your not up on all the properties of synthetic oil...because they also flow better at low temperatures (a lot of riders don't ride at 40 degrees C), have a higher film strength, and cling to parts better than conventional oil. All of which is very much applicable in bicycle suspension fork lubricating.
    Reputation: Gman086's Avatar
    It's not rocket science - just SPLASH oil! Any quality syn motor oil works great. I use Castrol Syntcec 5W-40 and the guys at Enduro Seal are using Amsoil 5W-40 syn.
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    www.derbyrims.com
    Reputation: derby's Avatar
    For splash bath oil, multigrade is handy cause you can also use it in your motorcycle.
    Synthetic doesn't absorb the water in the air as quickly, turning the oil into sludge.
    What's important is to change it often. It evaporates pretty quickly with good use.
    I've used 5w-20 (cheap stuff) in the lowers and the damper. It works perfectly.
    I've used Motorcycle 7wt in the lowers and the damper. It works perfectly.
    I then tried Power Steering fluid (cheap stuff) in the lowers and damper. It works perfectly.
    I use 75wt gear oil in the air chambers, which is basically Fox fluid.
    No matter what fluid I use, I can't tell if one is better or different than another.
    I could probably use cooking oil.
    It is more important to have clean oil.
    Woops. Double Post.
    Quote Originally Posted by mtnbiker72 View Post
    moaaar shimz
    Reputation: tacubaya's Avatar
    Oh hai guise
    Emailed Liqui Moly (which has some of the best fully synthetic oils available IMHO) and I got a response:
    Thank you for your inquiry and thank you for your interest in our
    products.There are seal sweller in every oil. We do not know if this oil work in the
    forks. We do not test this application. We are hoping to help you with our
    recommendations.If you have any questions about our Liqui Moly products
    We are very happy to answer your questions
    Mit freundlichen Grüßen
    Best Regards
    i. A.
    Michael Mayer
    Anwendungstechniker
    application engineer
    pvd
    pvd is offline
    Reputation: pvd's Avatar
    This is just silly. Buy some real suspension fluid for your forks! Honestly?!? You have a $800 fork on your bike but your not willing to get a $10 bottle of the right stuff.
    Red Line is the one to get:
    http://www.redlineoil.com/Products.aspx?pcid=18
    moaaar shimz
    Quote Originally Posted by pvd View Post
    Hey PVD.
    I was researching the use of Motor oil for lubrication purposes only, not for damping. I use Maxima RFF in all forks and Maxima RSF in shocks. I feel Maxima has great quality, performance and a good price.
    Btw, got a response from Mobil:
    Dear Mr. Tacubaya
    Mobil 1 does not contain seal swellers, but some Mobil 1 high mileage probably contain seal conditioners.
    Kind Regards
    Americas Technical Help Desk - supporting
    Mobil, Esso, and ExxonMobil branded lubricants
    email: tsc.americas@exxonmobil.com
  1. Mobil 1 5w20 instead of 15wt fork oil
    By wormvine in forum Shocks and Suspension
    Last Post: 09-01-2011, 09:03 PM
  2. Mobil 1 lube question
    By SGexpat in forum Tooltime
    Last Post: 08-03-2010, 03:02 PM
  3. Mobil 1 quick fix
    By theheavyone in forum Shocks and Suspension
    Last Post: 02-18-2008, 08:01 AM
