Results 1 to 2 of 2
    Mazz 55 RC3 leak on bottom of RC3 lower
    Tiny really. More damp. Crush washer need replacing or...
    Gulp
    A symptom of a goosed RC3 cart? Any ideas/experience??
    I don't think they use crush washers, just o-rings. Have you dissassembled the fork recently, and are there any signs of oil leaking from the top caps or the main stanchion seals? As oil flows downhill and any oil leak will end up at the bottom of the fork, so check for any oil trails carefully.
    It could just need o-rings for the footnuts, or if it is leaking from the compression adjuster I think the RC3 Evo cartridges can be dissasembled and may be able to reseal the adjust mech.
