Results 1 to 2 of 2
    Marzocchi MX Pro mix and match problems
    A friend is thinking of buying a 2008 MX pro (nos) from another friend but is not sure because it dosīnt have lock out. Just now I found a VTT unit 85-105mm with ETA for a 2003 fork for 14euros (new). My question today is, being a spring unit for a fork model 3 years older than what he has, would it be possible to swap out the air cartridge and install this in the forks left leg. Apart from the rebound damper, Iīm not sure what else is in the right leg and what it does seeing as it also has a schraeder valve on the top cap. Am I wrong to assume that the left leg is positive and negative air and the right leg is rebound and air compression?
    Anybody?
    Any information would be really helpful. I just need to know if I can swap the air cartidge from the left leg for the one I found for a fork 4-5 years older. The stanchions seem to be of the same diameter and the lowers donīt seem to have changed either from year to year.
