Results 1 to 3 of 3
    Vita brevis
    Reputation: rustus's Avatar
    Marzocchi MX comp leaking air
    I have an '04 mx comp that, aside from having to air up after every downhill run, I am very happy with. If anyone can Help me with stopping this air leak, I would appreciate it. I have had the fork rebuilt and that didn't help the air leak.
    Reputation: retro83's Avatar
    Did they change the seals? Also might be worth checking the valve cores are tight enough.
    B A N N E D
    Pump up the fork and brush some soapy water around the seals and valves, any escaping air will bubble up the water and show you where the leak is coming from.
