Results 1 to 5 of 5
    Mar 2006
    Marzocchi Dirt Jumper 2 top out sound
    I just got a brand new Marzocchi Dirt Jumper 2 on a Flow 2 DJ bike and when I pull up on the bars it makes a top out sound. Like metal clanging metal. I set the PSI for my weight. I tried speeding up the rebound and slowing it down. It still makes the top out sound.
    Another weird thing is when I flip the bike upside down, I can hear fluid moving. Maybe this is normal.
    Any ideas?
    Reputation: mullen119's Avatar
    Check your oil level, Sounds like you may be low
    Mar 2006
    Oil level - like bath oil or damper oil? I had a similar problem with a fox 40 rc2 and it was the damper seal that was loose allowing oil to leak out.
    i just got this fork and didn't expect it to be messed up. maybe i should warranty it or send it back to chainlove.com
    damper oil. marzocchi is known for sending forks out alittle low on oil every once in a while.
    Mar 2006
    ok thanks.
    anyone know where i can get the instructions to do the job? fairly simple? or should i send it to marzocchi under warranty?
