• 12-17-2012
    adcolgrz
    guys its me again hehe, what you think for put on on this fork brake disc avid bb5 with 160mm disc ? i have problem with v-brake when i turn its wipes brake on the rims but when i go straight its everything good... any ideas?
  • 12-17-2012
    cobba
    The v-brake pads rubbing could be from many things like loose bearings, fork flex, pads too close to the rims, loose axle, loose spokes, broken or cracked axle, broken or cracked brace that joins the legs, worn bushes in the fork, etc.
    Do you have the BB5 ?
    If yes, then you could put it on if your wheel has a disc hub.
    If no, then I wouldn't buy the BB5, I'd get the BB7 instead.
  • 12-17-2012
    Spec7
    It can also be from an improperly tensioned or simply a flexy wheel. I ran mine with both V-Brakes and disc. While running V-brakes, as long as I was running a Mavic 117 rim laced to a Ritchey hub, I would have brake rubbing on every corner. When I switched to Mavic Crossmax wheels with no other changes except for new pads, the rubbing almost completely disappeared.
  • 12-18-2012
    adcolgrz
    my rim front its simply and normal... noname... hub are ok and fork isnt broken, but i see that when i push fork to down and i turn wheel then in this moment are rubbing brake, maybe i need to try with other wheel more better as this my
  • 12-18-2012
    adcolgrz
    what king of adapter for disc i need for this fork ?
  • 12-18-2012
    Pau11y
    Something like this: Avid Disc Brake Adapter Front 160mm International Standard 74mm to 51mm | eBay
  • 12-18-2012
    adcolgrz
    thnx !!
  • 12-24-2012
    adcolgrz
    guys i have the last question hehe, for this fork i can put brake bb7 with 185 disc ? or this fork for disc brake its too much lighter and can broken ?
