Results 1 to 2 of 2
    Marzocchi 66 SL-1 ATA 2007 default oil weight
    Hi!
    I would like to know Marzocchi 66 SL-1 ATA 2007 default oil weight, because I was planning to replace oil. Do you use the same oil for air leg (left) also?
    Maybe you could give me some link to a more clear, guided instruction on disassembling the fork, because exploded view is not enough.
    Thank you.
    Sometimes has attitude
    Reputation: Marzocchi Tech Department's Avatar
    Quote Originally Posted by Mindauxx
    Hi!
    Thank you.
    Oil weight is 7.5wt fully snythetic
    Oil hieght = 65mm on the RC2X side, 50cc's in the SL side.
    Ride Your Bike!
