• 03-17-2008
    Mr.P
    Marzocchi 55 TST2 set-up help needed
    edit: UPDATE TO ORIGINAL POST BELOW WITH NEW SETTINGS: click here
    edit: UPDATE 2: TST2 damper pics
    edit: UPDATE 3: Possible modification
    edit: UPDATE 4: New settings and results. Cliff Notes version:
    .....Final opinion is that the damper's high speed compression is a bit over the top, not horrible for fast descending - but not great either, but the HSC rocks the freeride stuff!....
    I love the way the 55 TST2 handles big hits and has a pretty controlled behavior.
    But, I'm not diggin' the harsh small bump compliance at speed. Fast boneyards, braking bumps, etc. the fork feels like it is hydraulically locking up similar to a port orofice damper :mad:
    I have tried varying air pressures for preload:
    - 10 psi removes harshness, but the fork then behaves like it is undersprung (dive, weak midstroke, etc)
    - 28 psi feels more like the correct spring rate, but I get that hydraulically lock feel in the fast rough stuff
    I've checked oil levels, and am getting ready for the fork's first oil change (about 9 hours ride time). Oil level is currently at 55mm from top.
    I run my rebound pretty fast, but have not yet tested if I could run it faster in the high speed conditions to improve the situation.
    I think it might be the air preload side, as the open bath system might create some of this harsh feel at speed.
    (I am thinking this as the TST 2 damper does not have the harshness when under sprung (10 psi) - the TST2 damper seems to have piston/shim feel to it. Or maybe I am just feeling the air spring deep travel ramp-up on drops. And it really is an orofice damper :-( )
    Would running a lighter oil on the air preload side improve plushness in rough, high speed situations?
    If so what oil should I use?
    Marzocchi oil is Golden Spectro Cartridge Fork Fluid 7.5w (125/150), should I use Golden Spectro Cartridge Fork Fluid 7.5w (85/150)? or another? http://www.spectro-oils.com/products...n/cartfork.asp
    Thanks for any help.
    P
  • 03-17-2008
    flyag1
    Mr P,
    I agree 100% the fork is great for big hits! However, I don’t think the fork will ever be super plush on high speed bumps... at least with either of two cartridges I have ridden. (TST2 & R) We have tried zero and even negative pressure as well as 30 psi… harsh, harsh, harsh! And there will come a time when it get’s even worse… It’s a subtle change not something that seems to happen all at once. (Has happened to be twice)
    First time it blew my TST, all I noticed was the fork would not bottom. Normally I would bottom the fork as least once a ride, then all the sudden I could not reach the last inch or so of travel. I let all the air out and still could not bottom the fork. Sent it to Marzocchi and they installed a new cartridge. (At this point I had been riding the fork about 2 months and had logged about 150 miles) My normal air pressure was around 7 PSI.
    Got the fork back and it was smooth as a baby's butt in the high speed bumps, this was when I realized just how rough the fork was before. back to riding with about 7 PSI and getting 160mm travel. I managed to put another 150 miles or so on the fork, before I once again noticed the fork would not bottom, rode the fork anyway as it was a weekend trip… Fork was harsh in the small stuff, but handled the big hits just fine. Travel was limited to 140-150mm. I can’t really tell you the change took effect on one ride or in one week, it’s more like it happens over several rides and weeks. It’s like all the sudden you realize something just aint right and then you realize the fork travel is limited and the ride is harsh... I let all the air out and tried to force the fork to the bottom, no-go.
    I have a new TST2 cartridge in my possession, going to remove the old and have a look inside… Anyone interested in photos of the inside of the TST2?
    One other thing: one of my riding buddies blew his 55R damper… I helped him install the new one… could not see what’s inside as it is sealed… looks just like the hydraulic cylinder used to hold up a hatchback except both ends are threaded. You can compress the R cartridge but let it go and it will extend... I will say his 55R is just as harsh as the TST2 in small bumps, so you may well be on to something with your statement: “I think it might be the air preload side, as the open bath system might create some of this harsh feel at speed.”
    I have not seen the inside of the 55TST but I will soon… I have photos of the inside of the 55R and I will post both here on your thread… give me a couple of days.
    I don’t know much about forks or shocks but maybe if I post some photos someone will suggest modifications? Life is just a big experiment anyway, so why not modify?
    Good News on the horizon: Marzocchi is going to release a RC2 version of the fork this fall… so maybe we can change the internals of our TST…
    I am not a man of patience… fall is to far away… I am now riding a 66 RC3! 55 is in the closet
  • 03-17-2008
    Mr.P
    Originally Posted by flyag1
    Mr P,
    Thanks for the feedback! I was just reading your posts today, and was playing with lower pressures as a result.
    I responded to one of your posts a few months back where you described the small bump feel, and I bought the fork anyway...:rolleyes:
    And you are not the only one that has had a bad damper.... :rolleyes:
    grumble.... grumble....
    But I like the fork for all but the high speed spiking...
    P
  • 03-17-2008
    Mr.P
    I would love to see those insides. It would tell me if what is wrong is my set up (piston/shim damper) or it's the damper (orifice damper).
    P
  • 03-17-2008
    flyag1
    P
    I wondered if you noticed that statement? I will be changing my cartridge soon and will post images here for all to enjoy....
    Are you getting full travel on your fork?
  • 03-17-2008
    Mr.P
    Me likey pictures :thumbsup: thanks!
    I just checked the travel and I get full travel.
    Gotta ask how the 66 RC3 is?
    P
  • 03-18-2008
    farmboybunk
    I haven't worked on the newer tst systems, but have on the old tst that came on 05 and 06 all mountain 1's. My brother has one of each, and I have changed the oil in the open bath and cartridge for him. I replaced the open bath with 5 wt silkolin (I'm not sure what the correct spelling is, and i'm to lazy to look it up), from the stock 7.5 golden spectro, and replaced the cartridge oil with 2.5 golden spectro. The forks became much more lively, and less harsh. Before the only setting on the 5 tst that was operable was full open. After the second setting also worked when less brake dive was needed.
    So if it's possible try swapping out the cartridge oil for a lighter oil.
    Bunk
  • 03-18-2008
    Mr.P
    Originally Posted by farmboybunk
    I haven't worked on the newer tst systems, but have on the old tst that came on 05 and 06 all mountain 1's. My brother has one of each, and I have changed the oil in the open bath and cartridge for him. I replaced the open bath with 5 wt silkolin ...
    Bunk
    Thanks! That is helpful. I think the TST damper is a closed unit for Marz only service. I hope not, as I would like that adjustability and frequency of service for myself.
    Like your experience, I am only getting noticeable full open or lock-out, can't really feel a difference with the settings in between.
    It'll be interesting to see the cartridge innards when flyag1 posts with the pics.
    P
  • 03-23-2008
    Mr.P
    Update To Original Post
    UPDATE
    I was able to ride the same trails and stunts as my original post but with different settings, based on feedback and my own feel.
    The spring side oil weight has no relationship to damping as far as I can tell so I was way off base on that one.
    I lowered air pressure to ~22psi, oil level at 55mm and sped up rebound. Pre-ride I turned the bike (fork) upside-down for 30 seconds and cycled the fork an inch or two a couple times. This gets a fresh coating of oil to the upper seals and stanchions eliminating stiction thereby greatly increasing small bump compliance, especially at low speed.
    I am happy to report that small bump compliance has improved while maintaining big hit capabilities. Stiffening through the boneyards is greatly reduced, tho a bit still remains (but it feels similar to a 36 Van I've ridden, and a TPC+ Nixon). The stiffening now feels more "fluid" than the "spiking" of my previous report - firm but not harsh. :thumbsup:
    I think I had the fork over-sprung and perhaps a bit over-damped in the rebound circuit.
    For me (180#, 06 Enduro, ride fast straight through boneyards, jumps, etc.) the recommended air pressure (0-15 psi) is too low. It felt to undersprung and gave no pop for jumps or bunny hops - while my rear had pop = Mismatch! Yikes! :eek:
    So great improvement with better settings. I still have more tuning which should improve things a bit. Next up is to lower the oil level to get closer to full travel, and should reduce some of the spring rate ramp-up in mid-stroke that affects the fast bump compliance. Bottom line is that this was ride #4 and things should improve from here as I keep noodling and the fork breaks in more.
    P
  • 03-26-2008
    flyag1
    Cartridge from 2008 Marzocchi TST2
    " width="549">
  • 03-26-2008
    flyag1
    2008 Marzocchi 55R
  • 03-26-2008
    Mr.P
    Hmmm. That is interesting. Looks kinda like a TPC set-up - set top piston separated from the rebound and oil gets pushed up.
    Can't tell if it is a orofice or piston/shim damped.
    P
  • 03-26-2008
    Mr.P
    2008 Marzocchi 55R
    I am surprised by the "R" cartridge. I expected it to just be neutered TST2, but it looks very different.
    Thanks so much for the pics flyag1 ! :thumbsup: :thumbsup: :thumbsup:
    P
  • 03-27-2008
    Mr.P
    3 Attachment(s)
    TST2 Cartridge insides!
    flyag1 sent me these pics of the inside of the TST2 damper and did my best to point out the different functions.
    We both have questions as to how the damper locks out as the lock-out orifice is on a separate top piston assembly rod than the compression piston and shim which is on the bottom assembly.
    The good news: TST2 has piston/shim damping for both compression and rebound. :thumbsup:
    The bad news: how can such a simple looking system have the number of failures that are showing up? :confused:
    I'll let the pics speak for themselves.
    Thanks to flyag1 for taking the damper apart and for taking the time to take such great pics :thumbsup:
    P
  • 03-27-2008
    Warp
    P
    Bro, that's great info...
    However, I think you have it a bit mixed up. The piston on with the lockout is indeed the compression. All open with just a stiff blow-off when you close it. Very ETA-like.
    The rebound is the lower piston... What you see with the spring washers are just check valves (one way valves) that allow free flow in one direction and restrict the flow in the opposite.
    How this simple system can fail by limiting travel little by little?? I have no clue... Other than oil migrating from the semi-bath to the cartridge. Because high oil from the get go, will just limit travel from the first time you use the fork.
    Maybe air build up in the cart as in MX forks???
    Also, I don't see special tools needed to service it and looks dead easy to work on, but you can confirm if that's true or not.
  • 03-27-2008
    flyag1
    Thanks Warp,
    The cartridge was very easy to open... just unscrew the both ends off a threaded tube... and your done... I do understand the (top) thing-a-ma-gig is the compression side and lock out... whereas the bottom is the rebound... and the check valve in the rebound side makes perfectly good sense as does the restrictor needle.
    However the top thing-a-ma-gig (lock out and compression) is not computing.... maybe I don't understand the fluid levels? should the cartridge be completely full of oil?
    If the answer is yes: then closing the the TST valve... (turning the lock out to the closed position) you basically block the top 50% of the cartridge... as if the cartridge is now only 1/2 it's original length... and the bottom 50% should still function normally.
    If the top 1/2 of the cartridge is air filled then we have a different animal. It this is the case, then on really big hits fluid could be pushed into the air chamber which could result in a negative pressure below the rebound piston. Basically the top portion of the cartridge becomes a blow off reservoir and without the extra volume the orifices in the rebound piston (check valve and needle) will dramatically restrict fluid movement.
    In second scenario: where there is air in the top 1/2 of the cartridge... and a negative pressure below the piston is possible... then failure of the cartridge performance can be induced by the vacuuming of oil into the cartridge from the oil in the lower portion of the fork. Basically, the seals in the lower porting of the cartridge allow the lubricating oil in the lowers to be sucked up into the cart... resulting in cartridge overfilling and loss of travel.
    How is that for root cause analysis? To prove the point, just put red oil in fork lowers and clear in cartridge, when cartridge fails then open cartridge and most likely you will find red die in cartridge oil. Tell Marzocchi to install two way seal in lower cartridge and issue fixed!
    Now we can start to work on a fix for small bump compliance?
  • 03-27-2008
    Mr.P
    I think you are right, that those piston/shims are check valves. Doh! That means the damping is orifice based. Boooo! That means only an oil weight change will affect the high speed spikes. Booo! :mad: 2008 and still orifice dampers. :rolleyes:
    Unless.... Those gigantic blow off shims get replaced with a proper shim stack.... Possible? The orifice already flows so much oil... And why make the blow-off so heavy duty any way. Marzo told me on the phone that mid-setting lock out was a bad idea during non-climbing, even tho there is a blow-off, it could crap the damper...
    P
  • 03-27-2008
    Warp
    Thanks Warp,
    The way I understand it, it works like a rear shock but with no separating (at least not floating) piston between the air and oil.
    Oil (and I have no experience at all with the TST2, so take it with a grain of salt) should be just covering the compression piston. As the plunger shaft that holds the rebound piston enters the cart, it will displace oil and occupy space into the air chamber.
    If you lock it, you just prevent oil from displacing and it will flow only if you go over the blow off threshold. Oil can flow back down thanks to the check valve.
    If you have the oil lower than the piston, then you can have the problems you're mentioning.
    For small bump compliance, try a pressure (the cartridge is pressurized, right??) lower than indicated and/or a lighter oil than stock.
  • 03-27-2008
    Mr.P
    Brilliant! Too much oil make sense. I just found this on Dougal's Manitou FAQs page:
    TPC manitous also need a large air space in the damper. This is because they work on displacement (volume change) and the oil level rises in the stanchion as the fork compresses.
    Too much oil causes hydraulic lock, too little causes cavitation and both can damage your fork.
    Great to know the damper is an easy break down.
    It seems the air springs in the ATAs are having issues. I wonder if the seals Marzo (Suntour) is getting are poor spec. Like the Fox "stuck down" epidemic of a few years ago (at least that was the official line).
    I dunno on the small bump compliance, I can only guess it is the air preload seals.
    P
  • 03-27-2008
    Warp
    P
    You're on the right track, P.
    Indeed, you would improve the damper by adding shims and closing a bit the main orifice.
    I don't know why the stiff blow off... The TST5 is equally stiff.
  • 03-28-2008
    Mr.P
    More pics!
    flyag1 sent over some more pics for posting. :thumbsup:
    They can speak for themselves.
    Tuning options on the damper seem to include:
    - lighter weight oil (the ham fisted approach - but effective)
    - modify the blow off with a thinner and perhaps pyramid shim stack ( I guess one would have to start with a good amount of shims based on what is stock)
    Anyone else with any more ideas?
    P
  • 03-29-2008
    Mr.P
    Potential Improvement to Damper
    So I got thinking about the blow off to shim stack, and began to think it is quite feasible.
    After all it would only be used when the oil pressure starts to spike.
    By putting lighter shims in a pyramid stack, lockout would be more like a platform, and high speed compressions would be directed through the shim stack reducing spikes. Does this sound accurate?
    Anyone have any thoughts on implementation? It's so easy to think about but reality is a bit different :D
    Pics of potential change below.
    flyag1 measured out the stock blow off shims:
    "There are actually 4 shims in the factory stack, (0.32 ID X 0.790 OD x 0.016 thick)"
    One other possibility would be to reduce to blow off shim stack to just one shim. It would not be a progressive stack but working in conjunction with the orifice damper, might reduce the high speed spikes. Thoughts anyone?
    Flyag1, was there any nitrogen in the cartridge? And if it is a seal issue that makes the cartridges crap out, any way for us to fix on a more permanent level?
    P
  • 03-30-2008
    Mr.P
    UPDATE: New settings, damper info and ride report
    Another ride :thumbsup: Another tweak. :D
    The Cheese gave me a good tip to lower my oil height (while at same psi) to reduce down the spring rate mid-stroke. It was on the to-do list as my 55mm (Marz rec) height was not giving me full travel (about 30mm short), but his input made me be a bit more aggressive.
    Settings:
    23psi, oil height 62mm, rebound fast as reasonable
    So I took the spring out and reduced the oil level to 62mm from crown.
    While the spring was out, I decided to run some tests on the damper:
    - no spring (coil & air), damper open = damper gets progressive at 60mm to bottom. Progressive to the point where it requires my full body weight to reach bottom. Air or nitrogen compression in damper? Me thinks less need for spring progressiveness. EDIT: it is the air in the damper side leg that was creating the progressiveness.
    - no spring (coil & air),damper closed to lock out = super damped but still travels, rebound is damped normally.
    Ride results:
    - Same trail as all above.
    - 150mm travel with a nose heavy landing on a 4' drop. :thumbsup: I'll save that last 10mm for a nasty oops incident.
    - Small stuff at a moderate speed was invisible (I think my turning the fork upside down to lube the bushings helped the small bumps)
    - 2-3" rocks at high speed were firm, but did not feel spiked like an RV type damper
    - I nose heavied a 4' drop, over shot the landing on a 6' gapper, poorly landed a near flat landing and the fork just sucked it up without complaint. I love this fork for that. :thumbsup:
    So, final opinion is that the damper's high speed compression is a bit over the top, not horrible for fast descending - but not great either, but the HSC rocks the freeride stuff!
    I need to try this fork at Downieville - which can get very fast and rough - to see if it is a keeper.
    Also, if the damper craps out on me, I might just try adjusting the blow off to a firm shim stack.
    I want to keep the lock out as it can make a fast & efficient ascender on short out of saddle steeps. Never thought I would say that about a 160mm fork.
    P
  • 03-31-2008
    flyag1
    P
    Mr P,
    TST cartridge has no charge (no air... no nitrogen)
    Yes the fork does get progressive... even with the spring side open,but it's not the TST cartridge. It's the fork leg itself, as it is sealed. Larger oil volumes in the fork legs will also allow greater buildup pressures inside the fork. Need a stiffer fork, add oil...need more travel and a softer ride take away oil....
    It's even possible to have negative pressure in the right side of the 55 TST. To set up negative, remove cap and spring from left side... unscrew cap from TST side and compress fork and press the top cap of the TST cartitdge back into the right leg and re-tighten the top cap. Try to extend the fork and you will find if very difficult as the negative pressure will not allow you to do so....
    Negative pressure could be used to decrease Crown to axle length?
    Negative pressure could be used as a top out bumper?
    Maybe the negative would provide small but plushness?
    Of course, negative pressure would decrease usable travel.
    I totally agree the shims are causing issues with high speed plushness. As you suggested I am experimenting with a lighter pyramid shape compression stack of shims, backed by a heaver stack. In theory small hits only require small volumes of oil movement, where as big hit will require larger volumes. The lighter shims at the beginning of the stack should allow small volumes of oil to pass the compression piston with very little resistance. The heaver shims behind the lighter stack should restricting total volume and induce pressure buildup inside the TST cartridge for big hits Hence: progressive travel... The air pressure buildup inside the sealed legs will aid in the progressive travel as well....
  • 03-31-2008
    Mr.P
    Mr P,
    Great info, thanks. So it is filled to the brim with oil. Doesn't the oil need a space to fill on compression?
    Doh! I forgot about the cartridge side!
    Very clever! I did something similar to my wifes fork, only created negative pressures on both sides to reduce coil spring rate. It worked great for her.
    I wonder if this could work for small bump stuff? I bet it would. It might pull down the sag a bit, but the key would be to find that perfect balance between left and right leg pressures.
    Or maybe just get a custom made coil for the coil side, no longer use the Air Preload, and let the static pressures add the progressiveness.
    There is already a coil negative spring on the coil side.
    P
  • 03-31-2008
    macadam
    Nice work guys. It great to see how the new dampers are.
    It is interesting to see how Marzocchi tried to overcome the problems of the TST5 cartridge. And what I mean here was the blowing of the blander. The old TST5 cartridge used the rubber blander for the amount of oil that was dislocated by the rebound rod during compression. If some oil leaked from the cartridge, then air would get in during the rebound phase. And air into the cartridge meant that the compression piston didn't work anymore (it needs to be completely in oil).
    With the new design the rubber blander is replace by the air chamber above the compression piston. The piston needs to be immerse into oil but, there needs to be a decent amount of air above it. So there is a specific amount of oil that needs to be put in the cartridge. At least this is what one can see from the pictures.
    Those my believe is that blown cartridges are due wrong amount of oil. The cartrige will be damaged if there is too much oil in the damper! Just think about it. Under compression the oil dislocate by the rebound rod will not have where to go (even if there is a bit of air in the cartridge the pressure will extremely rump up). And the only way out of the damper is the rebound rod seal or one of the seal s of the upper or lower caps. If one of these seals brake, than the oil will be out and there will be no compression.
    Thus I think that someone (Marzocchi!!!) needs to come up with the right oil levels for new TST cartridges. If I would have such a fork I would take out the cartridge and try to put as few oil into the damper as possible before using it. As usual Marzocchi has good design but screw things up at the assembly.
  • 03-31-2008
    Warp
    :yesnod:
    One thing... I may be dead wrong, but I seem to recall the TST2 had to be pressurized (at least for 2007's???) as people on a Spanish board was fixing the travel issues with the TST2's by letting air scape, letting some oil to come off and pressurizing again to 40psi or so (recommended by Marzocchi was in the order of 140psi or so).
  • 03-31-2008
    macadam
    Can one add air into the cartridge? Is there a valve on the top cap? Can't really see one in the pictorials. Can some post a picture of the top cap?
    It can also be that this year TST2 is different from the 2007 model. Any idea?
    I doubt there a valve with which one can set the pressure in the cartridge. Unless the blow-off shims don't need to be pressurized I don't see why needs to have air pressure into the cartridge.
    I really wonder how someone can "bend" that blow-off shims under compression and let the oil pass!
    Adrian
  • 03-31-2008
    Warp
    Adrian
    I think the 2007's were slightly different... But let's hope someone with first hand experience chime in.
    I don't see a reason to have the cartridge pressurized, either... When I get home I'll get the source where I got the info about the pressure on the 2007's.
    I also don't understand Marzocchi's reasoning behind the stiff blowoffs. The one on the TST5 is a heavy, thick shim preloaded with a stiff spring.
    <img src="http://img317.imageshack.us/img317/3278/pb200169da9.jpg" alt="Image Hosted by ImageShack.us"/><br/>By <a target="_new" href="http://profile.imageshack.us/user/warp2003">warp2003</a> at 2006-11-27
  • 03-31-2008
    flyag1
    Before anyone comments: my photochop skills are lacking:( but here is my understanding of the min oil level. You can also see the relative size of the air chamber above the rebound piston... per Marzocchi no pressure required . I was told to install the compression side of the cartridge, flip the cartridge pside down and fill the rebound side with 2.5 wt oil. Then insert the rebound piston / rod and torque. Following there instructions you will end up with the oil level as depicted in the cutaway... .
  • 03-31-2008
    Mr.P
    Ha! You are rockin' Photoshop!
    Did they ask you put the TST in "locked" position?
    Is the 2.5w oil different than what they specced? Or is the same?
    P
  • 03-31-2008
    flyag1
    No air ports on the 2008 TST2
  • 03-31-2008
    flyag1
    P
    Oil is spec... and they did not specify tst in locked position... hence: in our personal communication I wrote, " I think before we post the oil levels, I better verify everything works correctly"
    Almost everything in life is experimental:thumbsup:
  • 03-31-2008
    macadam
    Hi flyag1,
    this sounds pretty good. However, I would say that one would need a bit of oil over the compression piston, like 1 or 2mm above. If you follow the procedure you just describe, it might happen that the compression piston will not be into oil. And in this case the lockout, and the compression adjust will not work (similar to Rock Shox MC, Manitou TPC).
    I would rather mount the rebound first, then poor oil into the cartridge. Cycle the rebound rod couple of times (with the rebound fully open) to let the oil get beneath the rebound piston. You should have the rebound piston all the time covered by oil. Then I would measure the length of the compression unit, from the compression piston to the o-ring that seals the cartridge, lets say it has length X. Then, with the rebound rod fully extended (all way out the cartridge) set the oil level to X plus 1-2mm. In this way you are sure you have the piston sinked in oil. Then insert the compression unit, with the compression fully open. Basically is the same procedure like on the Manitou TPC/SPV forks.
    Adrian
  • 03-31-2008
    Warp
    I think you have the procedure right, the illustration wrong.
    As per the illustration, if you extend the rebound rod, you'll end up with the compression piston depleted of oil. So oil level should be very close to the very top of the cartridge when the cart is completely compressed.
    The procedure that was given to you is correct. You can do the other way around and measure the total depth of the compression assembly from the top threads to the upper face of the compression piston, then install the rebound rod, add oil up to the compression piston upper face depth and close the cart.
    It's pretty much like a rear shock... Just that there is not IFP. In a shock, shock compression will move the IFP making the chamber smaller, on the TST2 (and Micro??) the compression assembly is stationary and the cartridge compression will raise the oil level past the compression piston.... just like Macadam mentioned.
    Adam... I think air in the cart is not an issue... They just have to make sure oil covers the compression piston at rebound's full extensionas you well mention.
  • 03-31-2008
    macadam
    Thanks for the pictures. Now we have almost the complete description of the TST2.
    One more thing. How is the compression adjusted? is the same type of internal rod, like on the rebound?
  • 03-31-2008
    Warp
    Looks like it works like the ETA to me... An inner shaft inside the main shaft just closing/opening an orifice.
    <img src="http://img134.imageshack.us/img134/7162/dsc04580fb1.jpg" alt="Image Hosted by ImageShack.us"/><br/>By <a target="_new" href="http://profile.imageshack.us/user/warp2003">warp2003</a> at 2007-03-03
  • 04-03-2008
    arctic303
    Hi all - quick question I hope one of you can answer. My 55 TST2 has too much oil in (can't get the last 20mm of travel) and I've been told (by Marzocchi Tech Support on here) to let some oil out. Does this just involve loosening the nut at the bottom of the non-TST side?
  • 04-03-2008
    macadam
    Hi arctic,
    if you want to remove some oil from the TST2 I would open the top cap, the compression unit and remove from there. I would remove the compression unit completely and then measure the oil level such that it matches the length of the compression unit.
    Adrian
  • 04-03-2008
    arctic303
    Thanks macadam. Do you mean the large nut where the TST control is?
  • 04-03-2008
    macadam
    yes, the big top cap. Take a good look at this thread, and pay attention to the pics. Go through all the posts before working on the cartridge, there is great info which might come handy during the service.
    Adrian
  • 04-03-2008
    arctic303
  • 04-03-2008
    Marzocchi Tech Department
    You need to remove the TST2 cartridge from the fork. Make sure the lock-out is in the open position. Then loosen the nut on the bottom of the cartridge and compress it completely. You can also loosen the top cap. Do this with either open side up. When you compress it and comes out it is over filled. You can then reextend it and retighten the endcap and reinstall it in the fork with 30cc's of oil in the stanchion for lubrication. Make sure everything is tight. Game on.
  • 04-03-2008
    flyag1
    I have played with different fluid levels and here are couple of things to really watch for:
    First you must not over fill or you can't get full travel, that is where you are now...
    Second, to little oil and you will not have any compression dampening...
    Look back at the cutaway I posted a few days ago, you will see the minimum oil level. If you put just the minimum amount of oil in the cartridge with the rebound rod extended (all the way out) then when you push the rod into the cartridge you will displace a larger amount of oil then one would expect: the rod itself will displaces 30mm or fluid... this is not a misprint! 30mm or oil...
    So you want minimum oil levels to start with other wise it's becomes an airspring with compressed.
    Start with removing the top cap of the cartridge... there is no need to remove the bottom. The reason for removing the top is that the top (compression) piston is fixed and you can't cycle the piston which you will need to do... cycling the piston on the bottom will insure you don't have air trapped underneath...
    With the top cap and compression piston removed fill the cartridge nearly full and cycle the lower piston up and down to insure there is no air trapped below the piston. Now set the oil level @ 110 mm below the top rim of the cartridge. This will allow you 2mm of oil above the compression piston once the top cap is re-installed. Reinstall the top cap... done.
    Once you have the top cap tight you should be able to cycle the rod in and out with ease, there may be just a little resistance when the rod is fully inserted... just enough that the rod may try to extend on it own, an 1inch or so...
  • 04-03-2008
    You guys are rocket scientist!!
    Wow, You guys have it all going. I read the post and three of you are talking about two different versions and now ETA pics.. wow their partners.
    Here's the deal. TST5 with external bladder, TST5 micro has an internal bladder, TST2 has no bladder and YES, it works just like TPC (Not my doing).
    TST2 is designed to be a climbing feature with limited performance. Which means all positions other than full on and full off will have their limitations. Orifice damping is speed sensitive there is no way around it. It does what it was designed to do, lock-out and un-lock.
    The current version of the TST2 had a stack of washers on the compression ports to block compression flow when the top adjuster is turned to it's firmest setting. It does not blow off and will spike like a mad dog. This is an orifice damper. The compression ports on the piston never do anything. The washers that are on there will be the last part to move.
    Here's what can be done. I did it and like it too but you loose the lock-out and turn it into a ripping performance setting. You will need 3 shims @ 18mm x 0.15mm thick with an 8mm ID hole. You will also need 3 washers 11mm OD by 11 ID. They need to be about 1mm thick.... Warning, if you break it you will pay for a new one.
    So take the top compression assembly and unscrew the piston. It has thread lock on the bolt so a little heat will help remove it.
    Now, on what would be the top of the piston group (that you hopefully didn't drop and parts are everywhere), remove the 4 thick washers closet to the thread of the bolt.
    You can now install the 3x18x0.15 shims and 3x11x 1mm washers. Apply thread lock and reinstall the piston group on the shaft.
    Done. Now just refill the TST cartridge, introduce the compression assembly as much as possible, compress, and tighten the cartridge. Install it and check it out. You will loose a lot of the lock-out feeling but oh my god, on the trail you will have a nice range of compression. It will be subtle and welll controlled.
    The bladder style cartridges (TST5 and TST micro), I would not recommend doing any modifications unless you have a machine shop to help you out. Those systems are a lot more involved to create a compression feature, that's where RC2 comes in.
    Have fun, be careful.
    ....and I call this a day off....:nono:
  • 04-03-2008
    arctic303
    Sorry guys.. loosened the top cap but can't turn any further as the TST lever hits the side. Either this lever just pulls off somehow or I need to loosen the nut at the bottom?
  • 04-03-2008
    flyag1
    Just pull straight up it held on with o-rings.
  • 04-03-2008
    arctic303
    Getting there. Undone the top cap, now I can pull it up about 10mm but not any further. Do I need to undo the bottom now?
  • 04-03-2008
    arctic303
    Well.. all looks pretty simple inside except I obviously don't have the right tools for the job. Removed the cartridge but couldn't get the nut undone at all. Re-assembled it and now it's as it was (minus 20mm of travel) and the TST doesn't work at all. What a mare.. :cryin:
    [edit] - fiddled about a bit with the cartridge extending it and then compressing and the TST is working again. :D I did notice that even without the cartidge installed, I could only compress the fork to 140mm travel so it's obviously not the TST anyway. Maybe this is normal, perhaps the spring is just too stiff? Tried putting my whole weight on the front wheel but can't get that last 20mm. Still, it's better than it was half hour ago.
  • 04-03-2008
    flyag1
    I am interested to know if you could push the rod all the way into the cartridge when you had it out? If you could then everything is ok... no need to drop oil!
    Also, did you let all the air out of the left side before you tried to compress? It is not easy to compress... need to ride into a curb to hit bottom:^)
  • 04-03-2008
    Do you have ATA?
    If not, you have a spring and air preload on the opposite side. Just undo the other top cap of the fork, remove the spring and set/check the oil hieght. Sounds like you might have a 140mm fork.
  • 04-04-2008
    arctic303
    Yes, I could easily push the rod all the way in. Glad I don't have to fiddle with the cartidge - at least I know it's safe to ride and not going to damage it now. It was worth the hassle of removing just to find this out.
    I did let all the air out before compressing. I've only had air forks before so wasn't sure how easily I should be able to compress fully. If it takes more than my bodyweight to fully compress then that'll be why and I can live with that.
    Originally Posted by Marzocchi Tech Department
    Do you have ATA?
    No, I don't have ATA. I'm happy to leave it as it is until its due a service, now that I know that riding isn't going to damage it in any way. I don't (or shouldn't!) have 140mm, it's the 160mm OEM version that's stock on the Specialized SX Trail 2008.
    Thanks all for your help :thumbsup:
  • 04-04-2008
    Mr.P
    Here's what can be done. I did it and like it too but you loose the lock-out and turn it into a ripping performance setting. You will need 3 shims @ 18mm x 0.15mm thick with an 8mm ID hole. You will also need 3 washers 11mm OD by 11 ID. They need to be about 1mm thick.... Warning, if you break it you will pay for a new one. Have fun, be careful.
    Complete with shim measurements! You rock! :cornut: :cornut: :cornut: :cornut:
    Thanks so much for taking time out of your day to help us with such detailed info. We are just looking to make a good fork great. Your help is greatly appreciated!
    Now I gotta get dirty. :thumbsup:
    P
  • 04-06-2008
    Snakes
    You need to remove the TST2 cartridge from the fork. Make sure the lock-out is in the open position. Then loosen the nut on the bottom of the cartridge and compress it completely. Do this with it upside down. If it is over filled some oil will come out. You can then retighten the endcap and reinstall it in the fork with 30cc's of oil in the stanchion for lubrication. Make sure everything is tight. Game on.
    Procedure for AM2 SL is probably the same, what about the oil level, also 30cc's (SAE 7,5?)? I found out today that also my fork probably has too much oil, I can get only 140mm of travel, but I let some air still in the fork (left ATA side). Is it OK too let out all the air and try to compress the fork, or there should always be some air in?
  • 04-06-2008
    arctic303
    I did exactly that a couple of hours ago. Let all the air out, turned the bike upside down, removed the cap at the bottom of the left leg, fully compressed and let the excess oil out. All Marzocchi oil is 7.5wt.
  • 06-01-2008
    terribletom
    A few quick questions to clarify this procedure:
    how do I install the shims/washers? Are they staggered like shim- washer-shim-washer or shim-shim washer-washer?
    Also, which do you start with? Should the shim or washer be adjacent to the compression ports?
    Finally, where do I buy these washers and shims? I don't want to tear the fork down until I have all the right parts?
    Thanks for all the help!
    Tom
  • 06-01-2008
    Mr.P
    Tom
    All is answered here: :thumbsup:
    http://forums.mtbr.com/shocks-suspension/marzocchi-55-tst2-conversion-shim-damping-step-step-410874.html
    P
  • 06-01-2008
    Jayem
    Mainly they did it so we can sit here and reminis about the good old days of free-flowing compression valves, such as this HSCV one that I dug out of the bottom of a cart that I sawed in half. The "piston" that was attached to the shaft on an HSCV cartridge controlled the low-speed rebound-bleed, while this piston at the bottom controlled the compression. It was a stationary piston, but with the compression action of the fork and the piston above, fluid was forced in and out of it, which is why there were oil ports on the outside of the HSCV cart at the bottom.
    Now, the HSCV was a pretty simple and no-frills damper compared to what you'd find in in an avalanche shock, or even a current fox and RS fork, but it worked pretty well.
    Marzcocchi: Go take apart a fox damper...then get a clue!
  • 06-03-2008
    terribletom
    Yo dog, I read your thread with interest since I was having the same issue with my OEM 55 tst2 160mm that came on my '08 kona coilair. I also could not compress with the cart removed here's what the deal is: while compressing down continue to let air out of the left leg, push-bleed, push down further-bleed more. If you do this you will eventually get that last 20mm. This to me means this thing is real progressive toward the end of the stroke in the left leg with regards to air, it's probably this way to prevent harsh bottoming. I have yet to remove some oil from the left leg since I dont have the tool to take off the cap but that might help depending if it's been overfilled. I hope this helps.
    Next is the shim mod suggested by marz tech dep, piece of cake.
    Tom
  • 06-04-2008
    arctic303
    Tom
    Thanks Tom. I did push-bleed a bit at the time and think I gained some extra travel from it. I didn't have the cassette socket at the time so I was worried about letting too much oil out (I have one now).
    I had a play around with the air pressure at the weekend - I let most of the air out, just leaving in enough so that the fork extends fully. However, I noticed after doing a few jumps that I *think* I was bottoming out the fork, so I put some air back in. It was making a squeaking noise as I landed and went away with more air so I think that's what it was. The oil marks on the fork indicate I was getting at least 150mm - I'll put a cable-tie on next time I go out so I can measure accurately.
    The shim mod sounds good, but the lock-out is pretty handy. Not sure I'd want to lose it.
  • 07-20-2008
    fixxxer0
    okay i need some quick help - if available.
    i opened the nut on the bottom of the AIRPL side (with the flat red starfish looking cover on the top shrader valve) expecting to find another shrader valve and instead found about 3oz of suspension oil pouring all over...
    now id say mostly all the oil that was in the AIR PL side has been emptied onto my floor...
    first question - should there have been this much oil in that side???
    second question - can i use the bike with what little remaining oil is in there or does it need to be refilled with another few ounces ( 1 oz ~= 30cc)
  • 07-20-2008
    flyag1
    first question - should there have been this much oil in that side??? Yes there should be that much and more....200 CC of oil per Marzocchi
    Yes you can use the fork with that little oil but it will bottom out real easy and you will need to put in a lot of air to keep the fork up in the travel... I would just take off the top nut and fill that side of the fork until the oil level is 155-160 mm from the top of the opening...
  • 07-20-2008
    fixxxer0
    Just wanted to make a correction, based on my 2008 55 TST2 fork its a 27mm socket you need to grind down, not a 22mm.
    please verify for yourself before you spend an hour grinding down a 22mm with a file and emery lol
    although i don't know who in the world would do that before removing the TST2 switch to check for an approx fit (hahahah i was so pissed at myself for being that lazy)
  • 07-21-2008
    arctic303
    You're correct - I bought a 25mm wrench without bothering to check first. :D
  • 09-14-2008
    theFuzz
    Hi Tom
    I have a 2009 ATA arriving next week and am tempted to try this mod right off the bat. Another post mentioned an updated TST2 cart being available and I'm assuming this is in all 09 forks.
    Can you confirm? If its really updated for 09 I am tempted to just leave it for now.
    Thanks for the info!
  • 09-28-2008
    benedwards
    hey everyone, hopefully someone is still checking this thread.....
    well i was going to go forward with the mod described by Mr. P in his other thread (thanks to everyone over there as well) but before i could get started, i realized that my 55 tst2 was only getting about half of the regular travel. i went to the northstar bike bike a couple weekends ago and unfortunately have not been able to ride since then. the fork was fine when i loaded it into my car for the ride home, and i am only noticing the lack of travel now. any ideas as to what happened? i live at a fairly high elevation myself, so i dont know if its an issue of air pressurizing in the legs or what. also, the bike/fork were upright during transit in case anyone was thinking it was oil related. i dont know a whole lot about forks, so any and all help or suggestions would be very much appreciated.
  • 09-28-2008
    flyag1
    You could start by letting the air out of the fork and see how much travel you can get... it ain't easy to compress (even with all the air out) so get on top of it will all you got! If you going to do the mod it don't really matter anyway, just take it all apart do the mod and then fill as outlined in this thread.
    Good luck,
    Dale
  • 09-28-2008
    benedwards
    i forgot to mention it in my first post, but i had let all the air out of the fork. thanks for the reply- i was hoping someone would tell me to just go ahead with the mod, i just wanted to make sure that wouldnt exacerbate or complicate my lack of travel issue.
  • 09-28-2008
    flyag1
    By all means... take it apart and do the mod.... it makes all the difference in the world on small bump compliance! You can set all the oil levels when you put it back together and all will be golden.
  • 09-28-2008
    theFuzz
    Hey flyag1
    Have any additional pictures of the modded cartridge by chance? the one pic I have seen on the thread from yourself and Mr P looks like there are no spacers at all, just 6 shims..
  • 06-29-2009
    AndyPP
    "You can now install the 3x18x0.15 shims and 3x11x 1mm washers. Apply thread lock and reinstall the piston group on the shaft. "
    do these go on as 'shim-washer-shim-washershim-washer' or as 'shim-shim-shim-washer-washer-washer?
    If I go for 5 or 6 shims in a pyramid stack, do I still need to add the three washers?
    really fancy doing this to my 55s and all the info is great.
  • 02-13-2010
    Nagaredama
    Sorry to bring up this old thread....
    Is it possible to change to the TST2 fork from 160mm to 140mm? I've done the shim conversion and the forks works great. Now I want to reduce the travel. Anyone have a link on how to do it?
  • 02-13-2010
    Mr.P
    Credit Flyag1 for the pic.
    Do the opposite of this (the photo is for 140 to 160)
    P
  • 02-13-2010
    Nagaredama
    Perfect! I knew I had seen a picture somewhere of how to do it I just couldn't find it.
    Thanks again
  • 05-18-2010
    iamkickstand
    sounds like I have the often described tst2 failure. I first noticed a bit of travel gone away, and now I have about 50% travel.
    It sounds like the typical failure, my question is this, short of shipping it out and being with out a bike for weeks, can this be fixed at home at all?
    Also, would doing this mod eliminate the problem? or do I still have to get the current issue fixed first?
    http://forums.mtbr.com/showpost.php?...5=&postcount=45
    In all honesty I do NOT need a shock that turns into a rigid anyway, I want to set it and forget it and go ride, KISS principle in my life.
  • 04-22-2012
    Horacek
    ah my topic has arrived/exists. ive just bought a new 2011 55tst2 fork cheap!
  • 05-08-2012
    Horacek
    Ok, circa 4th ride and I've found the following: I'm struggling with a top-out on rebound and the forks are too linear. I weigh 210lb and if to make the forks responsive I need to drop the pressure. Too much pressure and the forks become too stiff. In addition no matter what I can't get the last two inches of travel on he stanchion - which says' too much oil? Although my question is I need more oil to enable me to drop the psi to get the forks more responsive?
  • 05-08-2012
    Mr.P
    Oil level will only increase the spring rate in the last inch or two of stroke.
    The coil spring is very light, at 210, you have to use a fair amount of air to increase spring rate. Which makes it notchy.
    Lube the stanchions on a regular basis - allow for some break in. It will get a bit better, but IME not fully go away.
    P
  • 05-28-2012
    Horacek
    P
    Does this work on the 2011 TST2? Looks like the right leg/TST leg? .......and an easy mod.
    I.e I'll pop the top off, ease down slightly - remove the travel shim and store in a box. Any oil loss out of the top- I'll top up/replace. This way no need to undo the bottom/remove the shaft?
    Looks similar to the Fox 36 float travel adjust that I've done previously to 140..
  • 05-28-2012
    Horacek
    285 uk £
  • 11-26-2012
    eyco
    P
    got a Q about the 55.. i have the 55tst2 and i feel its to hard, i cant get the full 160mm its only use 140/145.. i change the oil the other day and i notice the black spacer like in the picture mark as B.. can i just remove the spacer and it will use the full 160mm?
  • 11-26-2012
    two-one
    The black spacer will always have to be present, only the position dictates the amount of available travel.
    If you have trouble accessing the last 15mm of travel, you should reduce the amount of oil in the left leg (try about 1cm) so the final ramp-up will be reduced.
  • 11-26-2012
    eyco
    It have 70ml of oil, should i reduce it?
