Results 1 to 36 of 36
    May 2013
    Marzocchi 350 CR 2014
    I have just received these forks and I have them fitted. However there is loads of stiction and the fork sags very little and when it does compress the action is not smooth. With 0 pressure the forks do compress fully at about half of recommended pressure the fork starts to compress more smoothly. It feels like there is almost no lubricant around the stanchions or seals?
    Give it some time to wear in. On my 55cr I found I don't need to run as much air as is listed on their chart. Just run whatever pressure works on the trail for ya.
    Reputation: Kiwiplague's Avatar
    Could be worth checking the splash oil in the lower legs, as it seems every manufacturer lately seems to find it hard to put the correct amount in! They may be running a bit dry and causing the stiction.
    On the other hand, Marzocchi's forks have always had a tendency to take a while to bed in.
    I don't crash, I just have slightly uncontrolled dismounts!
    Dec 2009
    Mfg tolerances may have come to play. Unlike all my Dt swiss forks[ seems to be a signature] my 55 Cr was one of the smoothest fork I've had out of the box. Seals were packed with grease which helped the top bushing lube.
    I'd monitor and possibly return it if it doesn't smooth out after a few months riding. it's not normal if my 55 Cr is anything to go by.
    What pressure are you running? Mine arrived and had 90psi on them. And felt terrible.
    The manual doesn't cover the 350 at all. And the on line one is the same.
    I'm going to try 60-70 psi for 160 pound geared up.
    Dec 2009
    Should be the same as a 55CR. I'm similar weight and run 75 psi and 1 or 2 turns compression.
    If you're 160 geared up Id try 50 psi
    Dec 2009
    That's too low for such a linear air spring.Is their something wrong with your fork? I can bottom the fork at 75 psi , no compression. I rely on adding some low speed compression[ adds incidental HSC ] to prevent harsh bottom out .
    Don't try and tune for low speed plushness. Tune for plushness at speed. that's where they smooth out.They aren't a bike packing fork.
    I added a few CC's of oil to the air spring chamber through the Schrader valve to make the air spring more progressive. It now takes the absolute biggest hits to push the O-ring to the top, and it still doesn't feel like it bottomed out. So now it feels great in all conditions, with proper sag.
    May 2013
    I'm 160 lbs geared up as well.
    I haven't been able to really push my forks yet or but some real mileage on them as I'm recovering from a broken wrist.
    However I did some tests last night I was running about 80 PSI no gear so about 155 lbs. The result being not very plush, not very good on small bump and not good on fast repeated hits, however they were ok on bigger single hits. My reference is a 2013 RS Sektor RL Solo air.
    I have now dropped the PSI to 70 and will run the same tests again tonight.
    A guy on another forum who runs some 55 CR that were purchased in the last few months has also had problems. His stanchions started to wear in lines and the fork felt stiff especially in the initial part of the stroke. They went back to the UK distributor who believes it is down to the wrong sized bushings in the lowers.
    Dec 2009
    You must have a very good sektor or a poor 350. Mine make a rev rct3 feel like a elastomer fork in comparison in all but fire road small bump compliance.
    May 2013
    Yeah I guess mine need sending back.
    They guy from the other forum got his 55 CR back and he said they were now really supple and none of the stifness/stiction in the initial part of the stroke.
    Mine still don't even sag properly.
    jzt
    jzt is offline
    Reputation: jzt's Avatar
    Hi, I had the same issues with my 350CR as well. Removed the lowers, spread some Molykote grease to the bushings, and seals, bolted the lowers back. Runs as plush as my previous 55 CR now. Not as plush as the Pike, but good enough, given they cost a lot less..
    I guys, I purchased mine one week ago.
    In the begiing of the stroke it has some stiction, but now after some hours of use it is becoming smooth.
    When going downhill at high speed I canīt tell the difference with the Pike in terms of damping, but I feel the MZ350 itīs stiffer.
    I hope that this fork will be as realible as the Pike I have using from 1 year ago.
    Apr 2014
    Any updates on the performance of the fork? How does it compare to the Pike?
    2014 Banshee Spitfire 650b
    2011-ish Chromag Samurai
    May 2013
    My beginning stroke had some stiction but appear to be getting smooth. Compared to my old Sektor RL the 350cr are much stiffer and also feel better dampened. However I still need to dial them in and as I'm recovering from a broken wrist I'm still not up to speed with my riding.
    Anybody have info on reducing travel on this fork? Prasedure ect
    Apr 2014
    Quote Originally Posted by jzt View Post
    any tricks to dropping the lowers? I'm not entirely familiar with the DBC cartridge or AER system, so I don't want to accidentally dump the cartridge or air spring oil while I'm just trying to grease up the bushings and seals. I've been told 20-25cc of 7.5wt Golden Spectro as bath oil in each leg.
    dropping the lowers is easy and doesn't require any extra care. Just don't remove the top cap from the damper side or you will disassemble the cartridge and will have to reassemble and bleed it.
    Thanks so just remove left side? Leave damper side alone
    Pop the red rebound adjuster out of the right leg (this may be a ***** it's a red plastic cap with a allen wrench molded into it, and is held onto the foot nut by spring clip, takes a bit of force to pull it off the nut). Then undo the foot nuts and slide the lowers off. Clean grease and slide back on, add oil through the foot nut holes before sliding all the way on and tightening down.
    Thanks very much for your help
    May 2013
    Quote Originally Posted by AlienRFX View Post
    So this almost the same as a RS lowers service? You don't have to touch the top caps? Do you have to undo the lower bolts a bit then tap them like RS?
    Apr 2014
    don't touch the knobs. my lowers pulled off super easily, no tapping required
    Jun 2014
    Quote Originally Posted by bottlerocketluv View Post
    you need to send the fork to us or take it to a trained shop. it is an easy process to reduce it but as CYA Insurance you need to have a shop at least do the work.
    Marzocchi USA
    1800-227-5579
    www.marzocchi.com
    Jun 2014
    Quote Originally Posted by fr0sty125 View Post
    I know this is late, I've been busy with the other forum and didn't think to look elsewhere on here.
    If the fork is still really sticky, feel free to contact our tech department and we will service it for free as a warranty. A lot of the 2014 model 350 forks were really sticky and took a while for the DBC system to fully lube the fork up so we have been fixing them up as people need them
    Marzocchi USA
    1800-227-5579
    www.marzocchi.com
    taste it
    Reputation: craftworks's Avatar
    Stiction was excessive on my 350
    Easy fix
    Just slid off the lowers, clean and apply suspension grease under seal. Fill each leg with 30cc of oil (no oil from factory)
    now it passes the stupid carpark test Pike owners base their performance guidelines on
    Quote Originally Posted by Marzocchi_USA View Post
    Jun 2014
    Quote Originally Posted by craftworks View Post
    Easy fix
    sounds good, just don't tell anyone you did that service if you need warranty work. having the end user take apart the fork voids the warranty, like an Apple product.
    Marzocchi USA
    1800-227-5579
    www.marzocchi.com
    Jul 2014
    I just bought my 350 cr last saturday and first time usage its leaking oil on the rebound adjuster knob? Is it normal? I also got 55 cr but its not like that when I bought it new.
    Jun 2014
    Quote Originally Posted by randycruz View Post
    No, that isn't normal. please contact our tech line as soon as you can. 1-800-227-5579 or tech@marzocchiusa.com
    Marzocchi USA
    1800-227-5579
    www.marzocchi.com
    Jul 2014
    Brought it back to LBS yesterday and they had it done within an hour. Still under observation but LBS guarantee i can bring it back if leak occurs again. They even put stanchion lube. It feels much better now. Thanks!
    Jun 2014
    FANTASTIC!
    I'm happy to hear that
    Marzocchi USA
    1800-227-5579
    www.marzocchi.com
    Hi, but if you stick with the stickiness after continual rides the dbc WILL sort out the stickiness? My 350R feel grauncy and I've not even fitted them yet! Would 5cc's(?) of oil in the airside help or just run them? Thank you
    Nov 2008
    I've just bought a 2014 350CR and have the same stiction issue. What oil are you using?
    Nov 2008
    Quote Originally Posted by killerisation View Post
    Update: i used a bit of ATF in each leg and now its running smoothly.
    I'd highly recommend pulling the lowers, greasing up the bushings with suspension grease, and ensuring the lowers have the right oil volume. DO NOT push the damper leg while the lowers are off or you'll lose some damper oil.
  1. 2010 Marzocchi 44 Micro Ti 29 vs. 2014 Fox 34 Float 29
    By zuuds in forum Shocks and Suspension
    Last Post: 06-18-2014, 10:10 PM
  2. Marzocchi 55 Micro STA 26" Fork 2014
    By digifun in forum Shocks and Suspension
    Last Post: 03-26-2014, 12:28 PM
  3. 2007 Marzocchi 66 Fork VS 2006 Marzocchi 66 Air Adaptor
    By jdiabolik in forum Downhill - Freeride
    Last Post: 02-24-2014, 11:44 AM
  4. Marzocchi 2014 150/160mm models ?
    By dclxvi in forum Shocks and Suspension
    Last Post: 07-03-2013, 05:55 AM
  5. Marzocchi 44 RLO or Marzocchi Marathon LR Suspension
    By aL1 in forum Shocks and Suspension
    Last Post: 07-17-2011, 07:02 PM
Members who have read this thread: 4
