Results 1 to 2 of 2
    Jan 2009
    Marzocchi 07 66 rc2 eta travel adjustable internally?
    Are Marzocchi 07 66 rc2 eta travel adjustable internally from 180 to less? If so do you need and special parts of is it just a matter of moving spacers? Thanks for your help in advance!
    Mar 2005
    I dont think there is any way to do this. There have only been a VERY few modern Marz forks that have any ability to mod the travel (first year 66 IIRC and only 150 - 170) .
    To make this work, you need a shorter main spring(s), and longer negaitve springs (or spacer). The main spring you can get to to swap out for something else...but the silly crimped and non servicable cartrages means that you cannot access the negative spring assembly. Without this (longer negative spring), no matter how short the main spring is, the fork will be able be able to extend to full length.....
