Results 1 to 3 of 3
    Marz Z1 FR SL: rattles after seals replacement
    Hi,
    My Marzoochi Z1 FR SL (2003) came back from seals replacement with some stickiness that has converted to noticeable 'play' after 10 or so rides.
    Basically, it rattles during the ride and, I can even feel few millimeters play in the front wheel (when I hold the rim an pull it compared to the fork.
    Any idea what can it be?
    Thanks,
    Dan
    Mar 2005
    Double check the hub first. If you have another wheel, put it in to check.
    Nop, the hub is fine
    Like you said, I've tried it with another wheel and the problem remains.
