Results 1 to 3 of 3
    Manitou tower pro 100mm oil got inside spring
    last weekend I serviced my Manitou tower pro 100mm (year 2011). I saw oil semi path from low leg got in spring side?
    is it normal or something broken? if yes what do I need to fix it?
    Thank you
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by hlmyd2002 View Post
    Thank you
    Not clear what you are trying to say.
    Some Tower info: http://www.jonesparkchronicles.com/ManitouTowerPro.html
    mtbtires.com
    Hi Shiggy,
    sorry, I will try to explain:
    For some reason my fork oil from lower leg is leaking into the spring in the stanchions.
    Is that normal? or is something broken?
  1. Manitou Tower Pro 2012 coil spring
    By solitone in forum Shocks and Suspension
    Last Post: 04-26-2013, 01:31 PM
  2. Manitou Tower Pro Spring Manual
    By thomllama in forum 29er Components
    Last Post: 10-28-2012, 12:20 PM
  3. Manitou Tower PRO 120mm FIRM spring
    By Crockpot2001 in forum 29er Components
    Last Post: 07-04-2012, 06:18 AM
  4. 2011 Manitou Tower Expert 100mm
    By gregnash in forum Shocks and Suspension
    Last Post: 08-11-2011, 07:21 AM
  5. Replies: 3
    Last Post: 02-18-2011, 04:20 AM
