Results 1 to 5 of 5
    Manitou shock/fork pump & SPV pump, what's the difference?
    In the 2004 (and many other years') Manitou manual, the Manitou shock pump is described as part number 85-4069. In the same manual, a dedicated SPV pump is cited as part number 85-4161.
    You can see what I mean with any of these manuals:
    http://www.google.com/search?hl=en&r...&aq=f&aqi=&oq=
    What is the difference? Why a spcial SPV pump? They both use schrader valves... One has a higher pressure calibration and the other lower?
    Please advise. Thanks.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    the SPV pump has a more precise gauge (up to 185psi IIRC). Works just the same as long as you don't need to read higher pressures
    better resolution guage, no big deal really
    Reputation: FlippinSweet's Avatar
    I have an SPV pump that I've replaced the gauge on in order to pump up my rear shock which is normally out of the pressure range of the SPV gauge.
    Thanks guys.
