Results 1 to 6 of 6
    Reputation: joshua_msu's Avatar
    Manitou Minute 2.0 100mm or 130mm
    I got a Fisher Cake 2 DLX with the stock Manitou Black Super Air. I want the Minute 2.0. Should I get the 100mm or the 130mm version?
    Reputation: AkDave's Avatar
    Smile You could get the minute 3 and run it either way...
    Quote Originally Posted by joshua_msu@hotmail.com
    Travel can be changed with the 3. That way if ya don't like the 130 length you run it in 100.
    Dave
    Well the minute 3 obviously costs more. I will now consider the minute 3.0 as well. If I do end up getting the minute 2.0 however, what size would be the best? Im 185 pounds.
    Reputation: slomoking's Avatar
    The 1:00 can be adjusted at either 100 or 130 and is the least expensive of the three. The 1:00 is coil instead of air though so it's a little heavier. If you are set on the 2:00 I would think the 130 would be better just because the Cake has 5 inches of travel in the rear. Just seems like it would be a better match. I have the 2:00 130 and find it to be an awesome shock.
    Chrome Toaster
    Reputation: Hecubus's Avatar
    You need the 130mm with the cake. It has a 70.5 degree headtube @ 130mm so 100mm would equal about 71.5 - 71.75, and that would suck.
    Thanks for the help. So I guess the Minute 3 would not actually be better anyho in this application since it is both 100 and 130 switchable. Obviuodly I wouldnt want a 71.5 tube angle, so no need for the Minute 3. Thanks again.
  1. 04 Manitou Minute 2/3 Set Up
    By MrSimba in forum Shocks and Suspension
    Last Post: 05-24-2009, 03:26 AM
  2. Need HELP dialing in Manitou Minute 2:00 and Swinger 4-way
    By bigDave in forum Shocks and Suspension
    Last Post: 04-20-2004, 12:06 PM
  3. Manitou Minute One vs. Fox Talas RLC?
    By dawgcatching in forum Shocks and Suspension
    Last Post: 03-17-2004, 09:36 AM
  4. Manitou Minute 3
    By DirtDad in forum Weight Weenies
    Last Post: 02-29-2004, 08:43 PM
  5. What to buy Manitou minute one or three.....
    By Edgar Nolasco in forum Shocks and Suspension
    Last Post: 02-18-2004, 11:40 PM
