Results 1 to 35 of 35
    Dirt Huffer
    Reputation: AC/BC's Avatar
    Manitou Marvel Pro or Expert users, STEP INSIDE!
    I cannot find any worthwhile reviews on this fork. I'm looking at the '13 Pro or Expert with 15QR.
    I'm most interested in hearing from people who have come from newer SID, REBA, or Fox F100 forks to try the new Marvel.
    And also i'd like to hear peoples opinion on if it's worth spending more to get the Pro. It looks like only a slight difference in weight and the rebound damping technology - Cartridge TPC (Pro) vs. Adjustable Detented TPC (Expert)
    Reputation: two-one's Avatar
    I'm pretty sure that the rebound&compression dampers function the same, but the Pro's are contained within a smaller cartridge to conserve weight. So in the end you are looking at only some weight-differences, but functionally identical
    I would actually love to get my hands on the newly announced 29er version. Should have the linear kind of air spring like a Fox, but with tunable shim stacks, and simple reliable construction, so DIY servicing and tuning will be a piece of cake.
    Reputation: ColinL's Avatar
    Feb 2012
    I was unable to find reviews, either, but I found the fork on sale bigtime at Chain Reaction Cycles a few weeks ago and I bought one for a new build, my wife's first MTB.
    It's a 2012 Julianna / Superlight. It was going to get whatever fork I could get for less than $400. I very easily convinced myself that the Marvel Pro was way, way better than a Recon or open bath Float 32.
    Unfortunately, as I posted in another thread here on MTBR, I can't provide riding feedback because there is no way in hell I can ride her bike at speed. It's about 3 sizes too small to contemplate it.
    I can tell you that if my own Float 32 120 RLC vanished today, I'd probably throw a Marvel on my bike. I suspect this fork has been a total sales flop, but even still, I have no idea why CRC is hundreds under everyone else. It's a steal of a deal.
    May 2012
    Just a quick FYI. Proicepoint has a sale going on right now for suspension items. OP might want to check this out:
    Suspension Blowout | Discounted Mountain Bikes, Road Bikes and Cycling Gear at PricePoint.com
    Dirt Huffer
    Quote Originally Posted by ColinL View Post
    Still wondering where the reviews are for this fork. It's not getting any exposure. I get tired of reading about the same brands over and over.
    Feb 2012
    Quote Originally Posted by AC/BC View Post
    It doesn't encourage loyalty when the big volume sellers have bouts of manufacturing defects. I've had many dirtbikes, both mx and enduro. I've NEVER had a fork or shock fail prematurely. It just doesn't happen. But there have been some amazingly bad, widespread issues with MTB suspension.
    I really like the Manitou Tower Expert I put on my FIL's bike. (It's big enough for me to ride, LOL.) So I figured between that experience and the paper stats of the Marvel, I'd take a swing. People have done crazier things.
    Personally, this fork makes no sense to me. They basically took their Minute fork, gave it an 80mm option and switched the spring/air assist to a air only setup. Saving a whole 68 grams from the Minute. Finally, they gave it QR/15mm axle options and "limited" the Minute to QR/20mm axle options.
    The only reason people even look at this fork is because they're not putting 15mm axle options on the Minute. Which forces you to the Marvel. Maybe they should put QR/15/20mm options on the Minute, dump the Marvel and put out an AM 140-160mm fork that they've been missing for the past 5 years.
    Reputation: mullen119's Avatar
    I dont know anyone with a Marvel, but those pricepoint deals are great! I wish I needed a fork!
    Quote Originally Posted by kan3 View Post
    The Marvel also has a different damper tune then the Minute. What they really need to do is remove the R7 from the line up and make the Marvel there only XC fork and keep the Minutes as more of an AM fork. Make a 160-170mm enduro fork and they have a complete line up.
    Feb 2012
    Quote Originally Posted by mullen119 View Post
    Yes. This seems to be the point of the Marvel, that they will not have shorter travel Minutes any longer.
    Dirt Huffer
    Ordered the Marvel Expert on CRC with coupon code GBP15 for $226.56
    Feb 2012
    Did you get your fork on the trail yet?
    Also... have you been able to find a MILO remote that is compatible with the ISO damper? All of them appear to be ABS+. I have not yet sent an email to Hayes/Manitou asking about it.
    DAlso... have you been able to find a MILO remote that is compatible with the ISO damper? All of them appear to be ABS+. I have not yet sent an email to Hayes/Manitou asking about it.
    There is no ISO damper: the spring is called the ISO-air spring, but the damper is still the same old awesome ABS+ damper.
    B A N N E D
    ISO is a air spring that's in the left leg, it isn't a damper.
    From the specs I've seen all of the Marvel models have the Absolute+ damper which is in the right leg,
    All Absolute+ dampers are MILO compatible.
    http://www.manitoumtb.com/technology/
    http://www.manitoumtb.com/products/forks/marvel/
    Feb 2012
    SWEET!
    Ok... so are all the MILO ABS+ remotes the same? I found it a little disconcerting that Chain Reaction Cycles has you pick which fork you have. If I clicked 'Minute' that would surely be fine for the Marvel, right?
    (Obviously, I bear responsibility for ordering something. I'm just curious what you all think. )
    Marvel pro gets rid of the negative coil spring for a self adjusting air negative. As I have reported, it is a great fork with far better dampening than a Fox.
    Riding slowly since 1977.
    B A N N E D
    SWEET!
    You should only need to buy a lockout kit, this kit will fit all ABS+ dampers.
    http://www.pricepoint.com/Brand/Manitou/Manitou-MILO-Remote-Lock-Out-Kit.axd
    http://www.chainreactioncycles.com/au/en/manitou-milo-remote-assembly-kit-2012/rp-prod57817
    You shouldn't need to but a lockout kit with the ABS+ damper if your fork already has a ABS+ damper.
    http://www.chainreactioncycles.com/au/en/manitou-milo-remote-lockout-abs-damper-2012/rp-prod57816
    http://www.pricepoint.com/Brand/Manitou/Manitou-MILO-Remote-Lockout-ABS.axd
    You'll only get to choose a fork model if you buy the MILO with the ABS+ damper, this is because the ABS+ dampers will be different in the different fork models.
    B A N N E D
    If you've bought the ABS+ damper with the MILO remote kit for the Minute then you can use the MILO remote on your Marvel Pro but you can't use the Minute ABS+ damper in your Marvel Pro.
    The ABS+ damper in the Marvel Pro is different to the ABS+ damper in the Minute forks.
    Look at the exploded diagrams and part numbers for the ABS+ dampers for the Marvel Pro and Minutes in the service manual, you'll see the different shapes and different part numbers for the ABS+ dampers in the different forks.
    http://www.manitoumtb.com/assets/Service%20Manuals/2012%20Service%20Manual.pdf
    Quote Originally Posted by cobba View Post
    The difference is that the Marvel Pro is a cartridge damper and the Minutes are in leg dampers. The higher end forks use the cartridge to save a few grams.
    Dirt Huffer
    I got the Expert since CRC had a killer deal. I'm waiting on my custom Ti frame to come to put it on. The knobs feel much higher quality then Fox. I had loose knobs on my Fox fork after a year and now they don't function at all.
    Reputation: los36's Avatar
    so, anyone care to follow-up with a ride report?
    -Carlos
    What I've been trying to figure out is if the offset on the minute or marvel will affect the handling of G2 geometry bikes? I see all manufactures have 51mm offset any input is great.
    Feb 2012
    It will steer a bit slower with less offset. For many XC type bikes this is not a bad thing unless you spend all your time <10 mph in the trees.
    Dirt Huffer
    Quote Originally Posted by los36 View Post
    I should have a ride report later in the month once I finish my build.
    Sep 2013
    I'd love to hear a bit about it as well. I'm in the process of building a Felt 9 with XX1, and from the sounds of it, the Manitou Marvel should be a great fork for a lighter rider such as myself (150 lbs). I have read that larger riders have a hard time setting them up though.
    Quote Originally Posted by InWyo View Post
    Larger riders have trouble setting up the Minute and Tower Pros. The Marvel pro uses a straight air spring that will be easy to set up no matter the rider weight.
    Sep 2013
    Are you riding the Marvel? If so, how does it stack up?
    I'm thinking of either getting the Marvel or the Reba RLT, but lack of reviews has me leaning towards the Reba...however the price and weight of the Marvel will give me some more flexibility on the remainder of my build. I road Manitou forks about 10 or 12 years ago, and I believe that was before they started having issues, and have been on difference incarnates of Fox Float forks since.
    Are they easy to set up, and do you have any thoughts on serviceability/durability as well?
    I got a Marvel Pro from CRC for $283 today, got it installed and blasted around my favorite local punishing ground and I have to say that in every way it is as good or better than my Fox 32 100 RLC (something bad happened inside the Fox, which is why I now have the Manitou). Damping is really nice and setup was easy. Smooth, stiff. I really tried my best to hurt it today, but it took good care of me.
    After the steer tube was cut, weight was exactly the same. 3.02lb.
    Dirt Huffer
    Is there anyway to purchase the Pro's rebound damper (Cartridge TPC) to convert an Marvel Expert?
    B A N N E D
    You'd probably also need the cartridge Absolute + compression damper with the cartridge tube for it to work.
    From what I can see the Expert and Pro use the same CSU and legs so you should be able to convert it if you buy the:
    Cartridge Absolute + Damper Assembly
    Cartridge Tube for the appropriate amount of travel
    Cartridge Rebound Assembly
    Part numbers are in the Service Guide: http://www.manitoumtb.com/assets/Ser...e%20Manual.pdf
    Maybe contact Manitou about it: manitoutech@hayesbicycle.com
    Aug 2014
    Just a quick review to say i am absolutely amazed by how good the Marvel Pro is. I got it like a few others here on a super cheap offer at Chainreaction, and I was expecting an 'OK' fork. Something that would just do the job. How wrong i was!
    I've now had a few months riding the fork and i've got to say it has excelled my expectations in every way. It's light, stiff and superbly damped. The adjusters make noticeable changes. The fork was pretty plush to start with but loosened up even more after a few rides.
    If i had to report some downsides, I would say the quick release is a little funky at first but you soon getthe hang of it, and the front disc hose cable routing is not the finest. Extra zip ties required to keep it where you want it.
    I've ridden xc, swoopy trails and steep gnarly trails (that'd i'd easily feel ok about riding my downhill bike down) and it has excelled in every department (and got me out of some sketchy moments!).
    5*s.
    Rich (not employed by Manitou)
    My version is the 120mm tapered steerer 15mmQR
    Reputation: Gabe3's Avatar
    2014 marvel pro 100mm. so far so good. I weigh 137 lbs. really smooth with small bumps. first ride: I had it with 50 psi, fork was too harsh on the larger bumps, yet butter smooth on small bumps, sometimes couldn't feel them.. only used about half the travel most of the ride. eventually travel indicator got bumped up to 1.25" left.
    second ride today. lowered psi to 40. my pump(and most I've seen) only have 3 marks between 0-50, then from 50-100 theres 4. so kinda tricky to know exact psi when under 50. smoother on medium bumps now. Looking for that small bump feel on the medium bumps, maybe its too much to ask for.
    I set it to 35 psi for tomorrow. fork sags on its own at that psi. I've left rebound knob at the half way point for both rides, and abs knob full open.
    Quote Originally Posted by Gabe3 View Post
    At your weight, you are going to need to mess withe the compression shim stack and maybe even the rebound shim stack. You are going to be over damped.
    I'll be over dampened till I change the shim stack? if the fork was tuned for my weight, how much psi would I use? I'll have to search your tuning thread for people at my weight. I don't know if their setup would still apply to the marvel if they are using a different fork?
    Think of the springs( air or coil) as holding the bike up. Shim stack is the ride quality. As long as the seals are stiction free, set the proper sag and then work with the shim stack. Oil viscocity only has a minute effect on the shim stack dampning oil flow. Going to pick up a Marvel Pro and looking forward to opening up the fork after a few rides.
  1. Manitou Marvel Pro Weight
    By Cary in forum Shocks and Suspension
    Last Post: 04-19-2014, 11:09 AM
  2. Anyone riding a Manitou Marvel Expert fork
    By Frozenspokes in forum Shocks and Suspension
    Last Post: 01-07-2014, 04:57 AM
  3. Fox 32 Float CTD 29 vs. Manitou Marvel TS Air 29
    By DeniDoman in forum Shocks and Suspension
    Last Post: 03-10-2013, 01:47 PM
  4. HELP: Manitou Marvel Pro vs RS SID WC
    By kobayashi in forum Shocks and Suspension
    Last Post: 09-24-2012, 07:36 AM
  5. Manitou Marvel...
    By CSC in forum Shocks and Suspension
    Last Post: 09-06-2012, 08:53 PM
Members who have read this thread: 13
