FAT BIKES
WINTER APPAREL
TRAINERS
Page 2 of 2 FirstFirst 1 2
Results 26 to 35 of 35
  1. #26
    What?
    Reputation: mullen119's Avatar
    Quote Originally Posted by InWyo View Post
    I'd love to hear a bit about it as well. I'm in the process of building a Felt 9 with XX1, and from the sounds of it, the Manitou Marvel should be a great fork for a lighter rider such as myself (150 lbs). I have read that larger riders have a hard time setting them up though.
    Larger riders have trouble setting up the Minute and Tower Pros. The Marvel pro uses a straight air spring that will be easy to set up no matter the rider weight.
  2. #27
    Sep 2013
    Are you riding the Marvel? If so, how does it stack up?
    I'm thinking of either getting the Marvel or the Reba RLT, but lack of reviews has me leaning towards the Reba...however the price and weight of the Marvel will give me some more flexibility on the remainder of my build. I road Manitou forks about 10 or 12 years ago, and I believe that was before they started having issues, and have been on difference incarnates of Fox Float forks since.
    Are they easy to set up, and do you have any thoughts on serviceability/durability as well?
  3. #28
    I got a Marvel Pro from CRC for $283 today, got it installed and blasted around my favorite local punishing ground and I have to say that in every way it is as good or better than my Fox 32 100 RLC (something bad happened inside the Fox, which is why I now have the Manitou). Damping is really nice and setup was easy. Smooth, stiff. I really tried my best to hurt it today, but it took good care of me.
    After the steer tube was cut, weight was exactly the same. 3.02lb.
  4. #29
    Dirt Huffer
    Reputation: AC/BC's Avatar
    Is there anyway to purchase the Pro's rebound damper (Cartridge TPC) to convert an Marvel Expert?
  5. #30
    B A N N E D
    Quote Originally Posted by AC/BC View Post
    You'd probably also need the cartridge Absolute + compression damper with the cartridge tube for it to work.
    From what I can see the Expert and Pro use the same CSU and legs so you should be able to convert it if you buy the:
    Cartridge Absolute + Damper Assembly
    Cartridge Tube for the appropriate amount of travel
    Cartridge Rebound Assembly
    Part numbers are in the Service Guide: http://www.manitoumtb.com/assets/Ser...e%20Manual.pdf
    Maybe contact Manitou about it: manitoutech@hayesbicycle.com
  6. #31
    Aug 2014
    Just a quick review to say i am absolutely amazed by how good the Marvel Pro is. I got it like a few others here on a super cheap offer at Chainreaction, and I was expecting an 'OK' fork. Something that would just do the job. How wrong i was!
    I've now had a few months riding the fork and i've got to say it has excelled my expectations in every way. It's light, stiff and superbly damped. The adjusters make noticeable changes. The fork was pretty plush to start with but loosened up even more after a few rides.
    If i had to report some downsides, I would say the quick release is a little funky at first but you soon getthe hang of it, and the front disc hose cable routing is not the finest. Extra zip ties required to keep it where you want it.
    I've ridden xc, swoopy trails and steep gnarly trails (that'd i'd easily feel ok about riding my downhill bike down) and it has excelled in every department (and got me out of some sketchy moments!).
    5*s.
    Rich (not employed by Manitou)
    My version is the 120mm tapered steerer 15mmQR
  7. #32
    Reputation: Gabe3's Avatar
    2014 marvel pro 100mm. so far so good. I weigh 137 lbs. really smooth with small bumps. first ride: I had it with 50 psi, fork was too harsh on the larger bumps, yet butter smooth on small bumps, sometimes couldn't feel them.. only used about half the travel most of the ride. eventually travel indicator got bumped up to 1.25" left.
    second ride today. lowered psi to 40. my pump(and most I've seen) only have 3 marks between 0-50, then from 50-100 theres 4. so kinda tricky to know exact psi when under 50. smoother on medium bumps now. Looking for that small bump feel on the medium bumps, maybe its too much to ask for.
    I set it to 35 psi for tomorrow. fork sags on its own at that psi. I've left rebound knob at the half way point for both rides, and abs knob full open.
  8. #33
    What?
    Quote Originally Posted by Gabe3 View Post
    At your weight, you are going to need to mess withe the compression shim stack and maybe even the rebound shim stack. You are going to be over damped.
  9. #34
    Quote Originally Posted by mullen119 View Post
    I'll be over dampened till I change the shim stack? if the fork was tuned for my weight, how much psi would I use? I'll have to search your tuning thread for people at my weight. I don't know if their setup would still apply to the marvel if they are using a different fork?
  10. #35
    Think of the springs( air or coil) as holding the bike up. Shim stack is the ride quality. As long as the seals are stiction free, set the proper sag and then work with the shim stack. Oil viscocity only has a minute effect on the shim stack dampning oil flow. Going to pick up a Marvel Pro and looking forward to opening up the fork after a few rides.
  1. Manitou Marvel Pro Weight
    By Cary in forum Shocks and Suspension
    Last Post: 04-19-2014, 12:09 PM
  2. Anyone riding a Manitou Marvel Expert fork
    By Frozenspokes in forum Shocks and Suspension
    Last Post: 01-07-2014, 04:57 AM
  3. Fox 32 Float CTD 29 vs. Manitou Marvel TS Air 29
    By DeniDoman in forum Shocks and Suspension
    Last Post: 03-10-2013, 02:47 PM
  4. HELP: Manitou Marvel Pro vs RS SID WC
    By kobayashi in forum Shocks and Suspension
    Last Post: 09-24-2012, 08:36 AM
  5. Manitou Marvel...
    By CSC in forum Shocks and Suspension
    Last Post: 09-06-2012, 09:53 PM
Follow MTBR on Facebook
