• 09-12-2010
    Aresab
    Manitou 2006 Black Platinum vs. 2008 R7 Elite
    I am building a bike for a friend and have both of the forks above in the title. Both have little miles on them but I am trying to decide which of them stays and the other goes. The Black, a 2006 model has the Mars Air spring, TPC with Lockout (not TPC+) and is a 120mm fork. The R7 is a 2008 Elite with Absolute Damping (not ABS+) and has TS Air spring and 100mm of travel. The R7 is lighter, but I'm not a fan of the plastic tube on the spring side.
    Any comments? And why would you make that choice?
  • 09-12-2010
    mullen119
    Keep the R7
  • 09-14-2010
    mattsavage
    Sell the Black and buy an Absolute+ damper. Get MILO if he's a racer, stand up hammer kind of guy...
  • 09-14-2010
    Dougal
    If he wants a 120mm fork, keep the black. If he wants a 100mm fork then go for the R7. They're very similar forks and can both be tuned to do basically the same things.
  • 09-14-2010
    trailville
    I'd agree with this. They are very similar forks in performance. The R7 should be about a third of a pound lighter, but they are both light forks. Both forks are known to be a little flexy though, especially at longer travel so if you can run the 100mm R7, I would go that way, especially if you can get the absolute+ damper upgrade. I currently have an 80mm Black Platinum and a 100mm R7, and do notice some flexing in the R7. I personally wouldn't want to run either of these forks at 120mm.
  • 09-14-2010
    mattsavage
    I've always been a fan of the Blacks... I've had two Black Elite 120 with TPC+... Wasn't any flexier than the Minute 130 I replaced it with and still only 4lbs with the coil spring.
    If I could find one today with TPC+ I'd throw it on an XC bike over a newer R7...
    If I was the OP, I wouldn't put a 120mm fork on an XC hardtail, though. He should post up what frame he's putting it on.
  • 09-14-2010
    Aresab
    Thanks for the replies. Let clarify my post. I am keeping one of the forks for my daughter. Currently the Black 120 is on a Sette Riddik, and that frame can adjust rear travel from 3.5 to 4.5 so either will work. I am unsure what I am building my friend, since it comes down to how much money he has, could be a Sette Reken hard tail or an XC full suspension. I'm leaning toward keeping the black because there is an aweful amount of plastic in the R7. I don't plan to upgrade the damper, I did that with my Minute 140 and love ABS+.
