Magura Fork Meister Grease - Alternatives???
At ~£16 for a tiny tube, and the fact it is like tracking down hens teeth, I need to find an alternative. Seems to me like this stuff is just like plumbers silicone lube.
Anyone got a suitable alternative.
Cheers, N.
I've run slick honey in every fork I've owned....It is really good stuff and proven to work without harming the fork.
If you need more than a splash lube, like for o-ring contact areas, check out parker O ring lube...best stuff I've used, long lasting, and helps with sealing.
H
Plus one for Slick honey.
That is the grease to use for suspensions.
I'd get the proper stuff from a German site like bike-components.de along with the correct oil when you buy your next Schwalbe tire. I'm sure a little will go along way.
By chad1376 in forum Shocks and Suspension
Last Post: 09-15-2012, 04:42 AM
By crclawn in forum Tooltime
Last Post: 02-23-2012, 05:56 AM
By jrsbike in forum Cyclocross
Last Post: 10-18-2011, 09:25 AM
By jsac in forum Shocks and Suspension
Last Post: 05-27-2011, 01:31 PM
Last Post: 02-05-2011, 12:09 PM
- You may not post replies
- You may not edit your posts
Forum Rules
