Results 1 to 2 of 2
    Reputation: sallen's Avatar
    Dec 2004
    Magura Durin Marathon 120 Adjustable Travel Question...
    Anyone riding this fork? If so, how does the adjustable travel work? How many settings are there between 80mm-120mm?
    Any other thoughts on this fork? Not tons of info when I do a search.
    The fork is adjusted with a handlebar remote. Simply push the lever down and adjust the fork to desired ride hieght. The fork can be adjust to any setting between 80-120mm. The internals on our forks are all very similar so operation and performance should be the same as say a Thor or Wotan. You may be able to find more information on those forks.
    Hope this helps.
