Results 1 to 7 of 7
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    Lyrik floodgate mod help...
    referencing this thread I am attempting to remove the floodgate from my Lyrik. I removed the c-clip from the bottom but when I use my fingernails to pull the gold dome out it is providing quite a bit of resistance and seems spring loaded.
    Do I just pull real hard or am I missing a step.
    thanks
    EDR
    Jun 2005
    So I pulled harder than I thought I should and it popped out. I only have 2 pieces though. The c-clip and the dome shaped piece which is attached to a black piece via a spring. The pic below from the other thread shows several pieces.
    Did I miss something or do I have an old style (or new style) damper that is just different?
    This pic is not my MiCo but copied from another poster on how to do the mod.
    EDR
    Jun 2005
    Well, I probed a bit deeper with a dental pick and pulled out two more pieces shown above. The plastic piece below the dome appears severely deformed.
    Anyhow I guess I'm good. If you guys have anything to add I'd like to hear it.
    trail "cleaner"
    Reputation: AZmtncycler's Avatar
    Edr...
    Bout time you read up on this mod. It'll transform your Lyik and get you the small bump suppleness you've been seeking. That in combination with your PUSH'd RP23... you WILL love the 575
    No dabs allowed!
    EDR
    Jun 2005
    Quote Originally Posted by AZmtncycler
    Sounds good. Hope to get out to SoMo tomorrow to check it out.
    Apr 2013
    Do you still have the small washer/shim that came out of the lyrik? If you don't plan on putting the floodgate back in I would like to buy that from you.
    EDR
    Jun 2005
    Re: Lyrik floodgate mod help...
    Quote Originally Posted by jonathanz View Post
    I do, however I'm keeping the parts just in case. Sorry dude good luck.
    Give Rock Shocks call with the part number on hand. You can get it from their tech diagrams....i think. Maybe they'll help you out. Honestly it's a better fork without the floodgate.
