Lyrik Air to Coil conversion - why smoother?
I am considering changing my Lyrik Solo Air to a U-turn coil. What I'm not sure about is why this makes it smoother and reduces stiction? Surely it is still the same seals etc?
I think I know why, but let's see if anyone else comes up with the same answer!
Mike
you lose two seals for the air system.
So in the air system, the air cartridge, attached to the bottom of the lower leg, has seals against the inside of the stanchion, creating a volume above it which is compressed and hence this is the "spring". In the coil system, the spring is attached to the bottom of the lower leg and the top of the stanchion, with no seal into the stanchion.
Is this correct?
It has been discussed many times before in this forum, do a search.
Is this correct?
An air spring "cartridge" is self contained and independent of the stanchion for sealing. You have described a simple air piston using the stanchion wall to create the air spring. Design aside it does create a volume above and below the piston - positive and negative. There is a lot of info on this site about Solo & dual air systems. Moving to a coil reduces stichion for better compliance and smoother suspension action. Coils are not w/o their con's added weight, having to change coils to adjust the spring rate & most coil forks lack progression.
You basically lose the seals that holds air in the chamber. That seal needs to be pretty damn tight to not let several hundred PSI by on compression. That tightness = stiction.
Those who know, ride a Mojo AND a Mojo HD.
Quadzilla
 Originally Posted by benja55
Ok, whatever, cold water on my bike boner right there.
- You may not post replies
- You may not edit your posts
Forum Rules
