Results 1 to 6 of 6
    Reputation: Calles's Avatar
    May 2010
    Looking to replace rear shock with coil... Suggestions?
    As the title states, I currently have a Sette Flite with a Rock Shox Monarch 3.1 (6"/152.4mm) rear shock that came stock. I'm a heavier rider (205 lbs) looking to do some light downhill this summer. With my weight, even just doing 3-4 foot drops it easily bottoms out and I'm concerned that it just isn't going to hold up to any greater punishment.
    As such I would like to upgrade to a coil, but also make sure that I don't **** up the frame geometry or get something that's to soft/hard for me. Suggestions? As I'm sure most of you would like a price, I was thinking about 550 tops with the shock and coil. Thanks guys!
    Link to original build thread:
    My AM build for 11'
    The bike, put together:
    List of parts on the current bike:
    Frame: Sette Flite Am Frame W/Rockshox Monarch 3.1 399.98
    Fork: Marzocchi 55 RV Fork 2010 299.98
    Crank: Race Face Ride DH X-Type SS Cranks 74.99
    Guide: MRP G2 Mini-G Guide 109.99
    Post: Pro Vibe 7S Seatpost 28.00
    Bars: Nuke Proof Warhead 760 Riser Bars ~50.00
    Stem: Nuke Proof Warhead Stem ~ 40.00
    Cassette: Sram PG-950 9 Speed Cassette 2009 24.98
    Shifter: Sram X.9 Trigger Shifter Individual 2010 58.98
    RD: SRAM X.9 Rear Derailleur 2009 Short Cage 69.98
    Brakes: Avid Juicy 3s (used off ebay) 59.99
    Seat: Nuke Proof Plasma ~50.00
    Pedals: Nuke Proof Proton ~70.00
    Grips: Nuke Proof Lockon ~20.00
    Headset: Cane Creek 110 Zero Stack Headset 129.98
    Wheels: Shimano M525 / Sun Equalizer Disc 20mm 149.99
    "Some people think they can outsmart me... Maybe... I've yet to meet one that can outsmart BULLET."
    -Heavy
    [QUOTE=Calles;10379436]As the title states, I currently have a Sette Flite with a [COLOR=#000000][FONT=Arial]Rock Shox Monarch 3.1 (6"/152.4mm) rear shock that came stock. I'm a heavier rider (205 lbs) looking to do some light downhill this summer. With my weight, even just doing 3-4 foot drops it easily bottoms out and I'm concerned that it just isn't going to hold up to any greater punishment.
    You need to figure out what the existing eye to eye / stroke of the current shock.
    Do what Keen says, measure shock with ruler, then find out stroke. Then shop for another shock. FYI, nowadays air spring shocks are good. I think you would be happy with a DHX air shock or Monarch plus. Both are easy to bleed and service.
    May 2010
    [QUOTE=keen;10379584]
    Quote Originally Posted by Calles View Post
    The specs say 6"/152.4mm... Are neither one of these measurements the eye to eye measurements/stroke? Sorry for my ignorance. I guess I could measure manually, but I was trying to go just by the spec sheet for the bike.
    *edit*
    This is the spec sheet from pink bike. Is their a way to filter popular parts sites (jenson/pricepoint/whatever else you guys have in mind) in order to find something that will fit properly?
    RockShox Monarch 3.1 - Pinkbike
    -Heavy
    [QUOTE=Calles;10380337][QUOTE=keen;10379584]
    Isn't 6" the rear travel? Anyways as already mentioned measure the eye to eye w/ a ruler.
    May 2010
    As an update which might help those looking to give feedback: eye to eye it is 7.5 inches.
    -Heavy
  1. Rear tire suggestions to replace Ardent
    By bitewerks in forum Wheels and Tires
    Last Post: 05-22-2013, 05:49 AM
  2. Rear Shock FOX FLOAT L rebuild or replace?
    By sertek54 in forum Cannondale
    Last Post: 02-09-2013, 09:27 AM
  3. Sould I replace rear shock with a longer eye to eye one ?
    By suiramy in forum Shocks and Suspension
    Last Post: 11-30-2012, 07:50 PM
  4. How to Measure/Replace Rear Shock?
    By Sob Rogue in forum Shocks and Suspension
    Last Post: 06-02-2012, 08:19 AM
  5. Want to replace '99 rear shock with new
    By Metacomet in forum Shocks and Suspension
    Last Post: 02-08-2012, 02:46 PM
