Kronos Ti Springs now available direct
Can't find any contact info. on the web site. Looking for dimensions. Inside Diameter and free length for the respective weights. I need a 350" x 2.25" for my CCDB. They only list 2.5" in a 350 spring. Curious if the free length is too long to fit my shock (7.7/8" x 2.25"). Thanks for any info.
Never mind. found it here..
Springtime
Will these fit a cane creek double barrel? Seems like a good price.
Live fast, Die young, Leave a good looking corpse!
They do not cause the parameters ID (or I just haven't found)
but this picture is encouraging:
Borodulin, Are you following me around? I do like that picture. I picked up a used RCS spring after lots of research and thought it would work, but no luck. If I could just get the measurement for the ID I would be happy...
Im not sure what size the CC shock takes. I know Kronos has several ID sizes available but only the standard (dsp, fox, marzocchi) size is on sale.
Not follow, of course. Just our interests randomly identical. At the moment I am also looking for a titanium spring on a CCDB.
Unfortunately, the Kronos does not show the size of the ID..
There are two ID's available, 36.3mm and 38mm. Which is the CCDB?
Springtime
According the technical info from Cane Creek CCDB need a 36.3 mm ID and not less.
38 mm is likely for RS Vivid.
Then the standard spring should fit.
36,3mm ID is minimum for CCDB, anything less will cause rubbing to shock body if/when there´s some s*it between. 38mm is 1,5", used with Vivid / Romic / Avalanche shocks, but there`re several providers offering adapters for CCDB. So, both fits but 1.5" spring requires adapters. Mine are from K9 Industies, which also provides some Ti-springs and silly light steel ones.
Borodulin, I just bought a spring from Kronos, not sure how long it will take with the international shipping but I will let you know if it fits.
I got my spring and it fits great. I haven't got a ride on it yet, but I suspect I won't notice a difference. The spring is a little over 200gm lighter then the steel spring, and it looks cool.
Oh. Thanks..
So, Kronos Ti + CCDB = perfect fit? No scratch?
I honestly haven't ridden it yet, it is cold and miserable here, probably not any worse than in Russia though. The spring slid on without a problem though.
Great, thanks..
We have ice under the snow everywhere )
Hi, how long did shipping take?
I really need a new spring before I box up my bike and leave for the Canary islands in 2.5 weeks time (Swiss based).
I think it was a week or so. They were pretty good with communication so just ask them, they should have a good idea how long it will take.
Thanks, appreciate that.
I've dropped them a mail already telling them i need it before the 16th, so fingers crossed! :-)
- You may not post replies
- You may not edit your posts
Forum Rules
