    Jul 2013
    Kind Shock Eten Upside down
    Just bought the ETen dropper post and i read in the owners manual that if the post is turned upside down, because is has an open bath air/oil cartridge (beyond me what that means), the post will not function properly until you cycle the seat up/down a few times and/or wait for the air and oil to separate. I will be moving to an apartment and would like to hang my bike on the wall without worrying that the post wont function when i take the bike down, does anybody have an experience with this? Is there a specific angle at which it begins having issues (maybe hanging the bike by its rear wheel will be ok?)? and will repeated air/oil mixing cause the shock to function improperly long term if done many times?
    Reputation: dirtrider76's Avatar
    Sep 2012
    It will be fine once flipped back over.
    I like to fart when I'm in front of you on a climb
    Lightly salted
    Reputation: fuenstock's Avatar
    If you hang your bike upside down I would worry more about your brakes if they are hydraulic. With hydraulic brakes you don't want to store your bike with the calipers higher than the levers as this can cause any air in the system to end up in the calipers. Air in the calipers will reduce braking power and give you a mushy feeling brake lever and you might even have to bleed the brakes.
    Jul 2013
    wouldnt any air in the line at all reduce braking power and give a mushy feel? I thought it was a closed system so if there is no air in there now it should stay that way regardless of orientation?
  1. Kind Shock KS LEV
    By ericepark in forum Shocks and Suspension
    Last Post: 09-25-2013, 10:29 PM
  2. Rattle in Fox shock when frame turned upside down
    By sinfony78 in forum Shocks and Suspension
    Last Post: 03-01-2013, 12:47 PM
  3. upside down rear shock???
    By titoa5 in forum General Discussion
    Last Post: 04-29-2012, 09:12 PM
  4. Kind Shock LEV
    By h2ored in forum All Mountain
    Last Post: 02-27-2012, 04:48 PM
  5. ok to run fox talas REAR shock upside down?
    By Dichotomous in forum Shocks and Suspension
    Last Post: 08-13-2011, 05:22 AM
