Results 1 to 15 of 15
    Mar 2013
    ID Marzocchi Forks - Help needed! Air and coil?
    Hi, i'm new to mountain biking and would like to get into downhill etc. Im riding a cheap bike at the min to work but I have got a bike frame which I have had for years, that I want to finally build.
    Its a hard tail Orange Sub Zero BH 16"
    Any way, I don't have a clue when it comes to parts/suspension etc as I mainly used a BMX.
    I Have purchased some forks off ebay but they have no stickers, just wondering if anybody could help me ID them as I think the seal has gone.
    They are def Marzocchi:
    Mar 2013
    can i not post images yet?
    Mar 2013
    ok then, here is a description. they are black with chrome bits, no v-brake mounts. they have valves on each leg. look like some kind of Dirt Jumper or Dirt Jam
    Mar 2013
    takes 9mm spindle
    Mar 2013
    they also have yellow springs inside each leg, but also both legs have the air valves?? is this normal
    Mar 2013
    Mar 2013
    Mar 2013
    by the way the yellow/gold things i think are just dust caps??
    Reputation: tune's Avatar
    I think that it is Marzocchi Dirt Jumper 3 and model year probably somewhere around -04. Dust caps have been changed. I once had the same fork.
    Edit: Check this: Tenneco Marzocchi Suspension - 2004 forks - DIRT JUMPER III
    Mar 2013
    hi, thanks for replying. thats what i was thinking, however after looking inside i found yellow springs/coils. but it has the valves to pump air in aswell so im confused,do you think these are these air forks or coil forks? cheers
    It is coil spring with air preload/assist. So it is sort of both (coil and air) springs combined.
    Mar 2013
    ok great, next question, the right leg is leaking oil from the seal. does this mean new seals are needed?
    if so, would you recommend repairing the forks or just selling them and getting more forks? (i don't really have the money to buy new though)....basically are they worth repairing??
    cheers
    Mar 2013
    are they the 32mm seals?
    Quote Originally Posted by fil1 View Post
    It is highly likely.
    Well if stanchion tubes are not damaged and leaking is the only problem then it could be quite easy and cheap to fix with new seals and basic maintenance. Although I would have to say that it is not very sophisticated fork but still very reliable, easy to service and works best for dirt dumping use. Not the best for downhill use. You might want to repair that fork for now and save money and buy a better fork or even whole bike for downhill use in the future.
    As far as I remember, yes (32 mm seals).
    Mar 2013
    hi, thanks tune. i can get seals for £10 of ebay so i might try that first. other than cosmetic, the rest of the forks look ok.
    the main use to start with will be riding to work and back through the woods. and some weekend riding in the summer to get back into it. thanks for your help.
  1. The Marzocchi Roco 2006-2011 WC/ Coil R Coil rebuild thread
    By Nick_M2R in forum Shocks and Suspension
    Last Post: 02-13-2013, 05:29 PM
  2. Replies: 30
    Last Post: 12-30-2011, 07:14 PM
  3. Which Marzocchi 44 - Air or Coil ?
    By jbf in forum Shocks and Suspension
    Last Post: 12-15-2011, 12:46 PM
  4. Marzocchi TST coil for HD???
    By Record in forum Ibis
    Last Post: 07-31-2011, 02:10 PM
  5. Marzocchi 44 Micro Ti Forks - how to cange to coil???
    By checkpoint22 in forum All Mountain
    Last Post: 05-12-2011, 08:10 PM
Hot Deals
Contests
Latest Mountain Bike Articles
