Results 1 to 2 of 2
    dot
    dot is offline
    Reputation: dot's Avatar
    I want to reduce travel on my '04 Fox Float 100RL
    I want to make fork lower by 10 mm, 100mm travel makes the fork too high for my frame and spoils geometry seriously.
    Is it possible? I see Fox makes some 90mm forks for Specialized.
    Not dead yet, just playin
    Reputation: ohpossum's Avatar
    Quote Originally Posted by dot
    Yes it is possible and very easy to do. Follow the instructions on how to change the travel for Float forks in the manual. Fox sells 20mm and 30mm spacers, but you'll need to make a 10mm spacer to get the travel down to 90mm.
    op
    www.msmtb.org - Mississippi Mountain Biking
