    help with RS SID lockout please
    SID Race with mo co damper and pushloc refuses to lockout. i've tried with gate all the way + to no avail. ideas?
    MTBR Member
    Reputation: ncfisherman's Avatar
    Kinda need some more info to properly diagnose your issue - even then, it's difficult over the internet.
    My first thought(knowing little about your fork), is that the damper oil may be low which would effect your lockout.
    kgm
    kgm is offline
    Replace cable, housing, and damper oil. Call in the morning.
    Feb 2010
    Three possible causes:
    - low damping oil;
    - pushloc not adjusted right;
    - moco damper busted.
    If your fork is low on oil you can tell by putting your foot on the wheel and pulling up on the bars. If you hear the fork suck air when its fully extended they there's not enough oil in the damper. If so, release all air pressure from the fork (neg first, then pos) and compress the fork. If fork doesn't compress fully, your damping oil has run into the lowers and you'll need to change the rebound rod o-rings. If it does compress fully, the drain oil from damper and refill with recommeded amount.
    To adjust the pushloc, undo the grub screw on the spool, turn the pushloc on, rotate the spool by hand as far as you can so its in the locked position and then tighted the grub screw on the pushloc cable. It helps if you've got someone to give you a hand with this. If the pushloc is not pulling the spool to the full locked out position, the lockout will not work.
    If none of the above works, you need to pull out the moco and examine for damage or breakage around the bottom where the lockout turns to close the lower ports. Also the lower o-ring may be gone, allowing oil to bypass the moco cartridge.
