Results 1 to 3 of 3
    GOT ME A 29ER!!!
    Mar 2011
    Help with Fox Float RPL
    I'm not sure what is wrong with it. At first I thought the airsleeve needed maitnence so i put in new seals. Now the shock is leaking oil from around the lockout lever and the lockout lever is stuck in open position. Is this a problem with the damper? Do I need to send it to a Fox center or can I do it myself? Please help as I have not had experience with suspension before. Oh, and it is the 2010 model.
    Yep, you're going to need to send it back to Fox. You have air in the pressurized damper compartment, and Fox doesn't really let folks repair that like RS does. I had that happen exactly like you did and they fixed it pretty quick like totally free.
    Does it also make squishy noises when before it was silent?
    The shock isn't toast, it just needs a rebuild with new seals that they don't sell...
    GOT ME A 29ER!!!
    Mar 2011
    Yeah, it is squishing through the first third of the travel, thanks for the help.
