Results 1 to 7 of 7
    fox Vanilla 125 RLC Help
    Hey guys. Recently purchased a fox vanilla 125rlc from a freind along with a frame. It is an 05, last year they ran the brake post. I know the 06 ran a through axle lower. Anyone know if 1. I can just change the lowers to through axle, and 2. where in hell i can find those lowers
    Fox sells fork parts directly, so why not call and ask them?
    suum quique
    Did not know that i will have to call
    I have a 125 RLC.
    I'd be keen to switch to thru axle lowers at some point.
    Could you post your findings on this thread if poss??...
    Yeah sure dude. I will let you know. I plan on calling fox tommorow sometime
    Ok so just spoke with fox lowers are available, only problem is that for the 32mm stanchions it only comes in a 15mm through axle. I hate 15mm through axles. So thats out. The cost retail is about 200 so if you need new ones your screwed
    Thought you wanted the 15mm thru axle? Never heard of the 32 with a 20mm. I have no desire for the 15mm setup either.
    suum quique
