Results 1 to 49 of 49
    Fox Triad replacement for 2010 Stumpjumper
    Went off a 4 ft drop to flat on my 2010 Stumpjumper FSR. Then the shock decided to leak all of its oil, and the blue setting level now doesn't click into position and spits freely.
    From a search, it looks like this requires a complete shock rebuilt, and is $150ish. At this price, if I can get an RP23 in place of it, I'm thinking that may be the way to go.
    Is there any way to get an RP23 or other fox shock fitting in a 2010 SJ frame, maybe with slight modification? I know there are custom attachments or something on this frame geometry.
    Anything Push can do?
    idiom - raleigh hard rock
    http://www.idiomband.com
    Former Bike Wrench
    Get it serviced by Push...it will be good as new and be tuned to your bike, your weight, and your riding style.
    Push won't tune a Triad.
    That's why I'm thinking that if I have to sink in $150 for a rebuild, if I can replace it with an RP23 I'd like to do that instead.
    I've read push can change the length of the shock and get it to the 1.9" that the 2010 needs. I'm not sure on the linkage connection, though. I think I'll call push today, they probably know.
    Bike Addiction
    Reputation: 00sable's Avatar
    I swapped a X-Fusion 7.5 X 1.75 for a Fox 7.5 X 2.00 and had no problems. There is a long thread about the changes in the Speci forum. Search it. It may be some help. I don't think 1.9 to 2.00 would be much to worry about. Def check with PUSH.
    Disclaimer: Always get a second opinion cause I'm just guessing
    Jun 2010
    Not under warranty?? 4ft depending on landing and weight isnt that bad.
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    On my '08 Stumpjumper with a 7.25 X 1.75 Triad, I replaced it with a 7.5 X 2.0 Monarch shock, and it worked perfectly. I matched the front by replacing the 120mm fork with a 140mm fork and ended up with a perfect balance. As long as you don't get problematic "chain drag" at the front derailleur or other overextension issues at the rear swingarm, a slightly longer shock will work fine.
    I thought the '10 and later Stumpjumpers use some kind of proprietary shock clamp design?...or am I missing an option here?
    Reputation: dynamicz's Avatar
    Bumping this for more info as I am in the same boat.
    Has anyone tried contacting PUSH and send in their old TRIAD and RP23 to swap bodies?
    Push told me I was stuck with my triad due to the way it mounts to the rear linkage. Now, if you send in both an RP23 and the old triad and have them fit the triad stanchion on the RP23, it may be able to be done. But you're looking at about $500 at this point, even if they're willing to cobjob it...
    The 2011 Stumpjumper EVO uses a specialized tuned RP23, though, which I bet would fit in the frame and fit the linkage. I think the best way to go would be if you can get your bike shop to part one of these out. It's slightly longer (1/8" IIRC), though, so your BB will sit up higher.
    I am getting the opposite length:
    2010 Stumpjumper FSR 29 Comp:
    "Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, rebound adj., 7.875x1.8"
    2011 Stumpjumper FSR Expert EVO:
    "Fox RP23-S with Boost Valve, reb and separate climbing setting and custom 3-position low-speed comp adj., 7.75x2.0"
    Could be worth a try just have to make sure that extra 0.2" stroke coupled with the reduced length doesn't interfere with the frame linkage at full compression.
    Reputation: martinizer's Avatar
    Quote Originally Posted by dynamicz View Post
    The 2010 26er is 1.9".
    Anyone tried fitting the EVO shock on a regular '10 FSR yet?
    Aug 2005
    I think what happens is that the platform/lockout rod sort of get "spit out" from the rebound rod in a hard hit when the nitro pressure in the oil side of the shock does not manage to come though and hold the lockout rod in place. And once pushed out from it's o-ring, you have the leak. At least this is my retrospective schematization after working on this shock. IN fact, I think a problem with this shock is that the oring for the lockout rod/rebound rod intersection is simply a tiny bit to tight, leading to the often reported kind of undefined action of the lockout switch clicker funktion as well as to leaks as described above.
    What I did in the end was to simply fill the rebound rod's internals with some epoxy, the re-assebe the shock with the lockout thing (plus I did some shimstack rearranging). Works great, but you have to get into the internals to do it. See Breaking and entering the damper circuit on a Fox air shock
    About replacement shocks. The Triad from my 07 Stumpy is in fact a 7.5*2 shock that is internally limited to 1.8" travel with a nylon washer on the damper shaft (ie the oil side, so you have to dissassamble the shock to mount it unless you think of a smart trick to construct a washer like that that can be mounted without needing to remove the head of the shock from the inner damper shaft).
    On my 07, I'm 100% sure that running a regular 7.5*2 would make the link arm hit the main frame before the shock bottoms. Another option (on my 07 120mm travel frame... don't know about newer ones) would be a slightly longer shock with more travel. Those exist (200*56mm, would that be 8*2.2?). Then you would have maybe an inch extra travel but still no frame/link bottom out since the shock is 1cm longer and has 1cm more travel than the original one. But it will still be VERY tight to fit it and depending on some very fine details in the shape of the shock around the lower bushing area it might not work.
    www.derbyrims.com
    Reputation: derby's Avatar
    Quote Originally Posted by Ola H.
    About replacement shocks. The Triad from my 07 Stumpy is in fact a 7.5*2 shock that is internally limited to 1.8" travel with a nylon washer on the damper shaft (ie the oil side, so you have to dissassamble the shock to mount it unless you think of a smart trick to construct a washer like that that can be mounted without needing to remove the head of the shock from the inner damper shaft). ....
    On my 07, I'm 100% sure that running a regular 7.5*2 would make the link arm hit the main frame before the shock bottoms. .....
    Fox should have these spacers out now. They could also be stacked to further limit bottom travel. And limit air volume appropriately for the shorter stroke.
    http://www.pinkbike.com/news/tech-tu...acer-2011.html
    I called Fox customer service a few weeks ago about these. CS says they don't limit travel, but I it clearly appears from the pictures that their documentation is incorrect.
    Aug 2005
    Quote Originally Posted by derby View Post
    To me it looks like these will not limit travel. On one of the pics in the link you can see inside the upper part of the air assembly with the spacer mounted and you can see it does in fact not sit on the damper shaft but is pushed further up into the eyelet assembly. Since this part is thicker, this also explain the shape of the slit in the spacers, I reckon. You can freely slide them over the smaller diameter damper rod and then you push them up to lock onto the slightly larger diameter part where the damper rod screws into the upper eyelet assembly.
    Aug 2005
    And by the way, for this reason (how they mount) I also think it is impossible to stack them.
    Aug 2005
    To illustrate my point:
    Here is the travel reducer spacer, that sits directly on the damper shaft and limits travel (+ reduces air volume):
    Here is pinbikes pic which shows the (clear colored) air volume reducer spacer which instead sits inside the upper eyelet assembly and does not reduce travel:
    www.derbyrims.com
    Quote Originally Posted by Ola H. View Post
    I thought the damper outer body, the square end, compressed all the way to the top of the air sleeve, only cushioned by the o-ring (and air spring progression ramp up) from mechanical bottom travel.
    Quote Originally Posted by martinizer View Post
    The EVO wasn't out when I was looking. If you can get your hands on one, I think it will work since it has the same mount as the normal SJ. The trick is getting the EVO shock when you don't own the bike. If you're in good with a shop, it may work.
    Aug 2005
    No, the square end of the damper body hits the cylindrical part of the air sleve/eyelet assembly that is visible inside the clear air volume reducer (cushioned by the oring). So the air volume reducer never comes into play (exept as an air volume reducer...).
    www.derbyrims.com
    Thanks for pointing that out. From that picture it does appear there is a depression the Fox air space kit fills. I haven't looked so closely in that area previously, and assumed the travel limit was simply the face of the can.
    If ambitious a travel limiting set of slotted spacers, could be stacked and bonded together to prevent sliding off the slot or rattling, to form a similar spacer as the Triad spacer.
    Reputation: Znarf's Avatar
    That is some interesting information!
    On my 2011 Stumpjumper 29er FSR Comp (and I guess that goes for the 2010 aswell), the shock is mounted in that new "unusual" Specialized way.
    There seems to be no DU-bushing, just a bolt and the linkage piece.
    Is there any difference to a standard fox shock?
    Would a standard Rp23 need any modification/machining (aside from the travel spacer?)
    My stock Triad is acceptable, but it feels a bit mushy and lacks low-speed compression.
    I'd rather swap it for a better shock, than paying big bucks for a service.
    Greetings Znarf
    Anyone got some new intel?
    Greetings Znarf
    Almost as good as you
    I'm in the midst of researching the same issue. After blowing out my second Triad II on my 2011 SJ 29er comp - I've got my LBS talking to Fox to see about options for upgrading to the RP23 - but the mount is an issue.
    Looking for more informed opinions and if new options exist since the above thorough analysis.
    IŽve since obtained a defective RP23 from a buddy. The "stanchion" or rather shock shaft is scratched pretty bad, but I wouldnŽt need that part anyway.
    If my shock blows - IŽll try to get Fox to take the shaft from my TRIAD and the rest of the parts from the RP23.
    But I might rather get the new Tallboy LT =)
    Uses a proper shock from the start...
    Greetinsg Znarf
    Has anyone found what x fusion shock might work in the 10 model?
    Mike
    Feb 2010
    Hi
    i have a 2011 stumpy with the triad, which has broken.
    i want to upgrade to an rp23, so i am making a link like the ibis ripley has, to convert a standard 200x50 rp23 to triad style lower horshoe link. i cannot show you a piccy because i am a noob! i have modelled it, and it is going on the cnc machine very soon. i hope it works.
    J
    Feb 2010
    i think i managed to load a piccy into an album, if anyone is interested
    Oct 2011
    Hi, your custom SJ link is very interesting. Did you managed to produce real one? I'm interested in one.
    Regards Milan
    Superhero in training
    Reputation: ColoSean's Avatar
    Sep 2012
    I'm a new member to this club. The Whole Enchilada in Moab sacrificed another rear shock to the mtb gods, for my enjoyment....
    Am I correct in thinking that Fox is the only one who services this shock? I sent an email to PUSH, but from this thread it sounds like they aren't going to take the job.
    How's the RP23/Triad combination working?
    Anybody come up with any other options?
    Hi,
    I bought a rp23 boost valve shock directly from Specialized.
    This shock originally came with the 2011 evo 29er.
    It fits, but I had to add two travel reducers.
    Which is easy, as you just have to unscrew the air can, put two plastic washers in there, finished. Just search for 650b travel reducer. There's a great thread from some Ibis guy on mtbr.
    Side note: the triad on my stump jumper was replaced after 6months. When I measured stroke on it, before ordering the rp23, I noticed that at full shock compression the brace on the seat stays hits the seat tube. Size XL. No problem with the reducers though.
    The shock itself feels a lot better than the triad. The rebound feels more sophisticated and a lot more consistent. Didn't do any long dh stuff on it yet. But I am pretty stoked on it.
    It does feel pretty linear, the boost valve seems to do that. At least with this particular pressure. Maybe I'll put some air volume reducers in there.
    Or I'll send it to tftuned, same as push, but in England, the even use Push parts.
    Maybe I'll have it custom tuned.
    But for the moment it feels good.
    I am especially happy that I now have a shock that will/can be serviced by Push etc.
    Obtaining the shock was actually pretty simple. I just contacted my specialized lbs and nagged the hell out of them. I did that until they nagged the hell out of Specialized. At some point they agreed to sell me a shock.
    They wouldn't sell me a Kashima shock however, "no way!"
    I was between selling the frame or buying this shock. I hated the triad after the second season. Didn't even have to service it, as the triads kept crapping out on me. Got them exchanged under warranty, which was very nice from the big S.
    Now I'll just ride the frame until it brakes and then replace it with a Tallboy or something.
    Greetings Znarf
    Sep 2012
    Thanks for the info, Znarf!
    Just an FYI- I got an email back from Push Ind. today and they stated that they will work on the shock. Think I'll just go with them and get it set up. I've heard lots of good feedback about their services. And they are in Colorado!
    Push Industries - FOX TRIAD/RPL
    has training wheels
    Reputation: DeltaNu1142's Avatar
    Quote Originally Posted by TNC View Post
    I'm going to PM you, because I'm doing exactly the same thing on my 2009 Stumpjumper (Triad to Monarch), and I don't know where to find hardware. The bottom bushing from the Triad fits both the bottom and the top of the Monarch perfectly, but I only have the one pair. Hopefully you're still around...
    2009 Stumpy 29er 1x9 Frankenbike
    Feb 2010
    but why the new linkage ??
    I do not like the philosophy of limiting the riders options.
    Se all this fuss, Jesus x ! a rear shock should be a personal matter of choice not limited by the bike company. Its close to a cartel activity....
    I am now looking at a Knolly instead.
    Sep 2012
    I had Push Ind. rework mine and they did a great job. Not the most affordable route, but top notch work. So far, no issues. I'd recommend giving them a call.
    Oct 2011
    My SJ 2010 PRO with SJ EVO'12 RP23. Dirt form first season usage. Works without any issues and without any modifications, only swapped for original brain shox.
    Milan
    Yep I got the same bike color and bike and changed my shock also. I think it works a lot better than the brain
    "It Is What It Is" Phil 4:13
    B-Ray Da Beast
    Oct 2011
    Difference between RP23 and original brain is huge! I was shocked on few first rides, bike is better in climbs for my surprise! And down the hill it id night and day! I'm absolutely happy with my bike, only SJ CARBON EVO makes me thinking of...
    Oct 2011
    this photo is better a bit...
    Apr 2013
    Quote Originally Posted by migadeath View Post
    Milan
    Did you purchase the rp23 second hand or from specialized? Also i have the same frame and notice your upper link is black. Did you have to change this for the rp23? I'm wondering because the original link is brown same as the frame. Also were you able to use the original link of the Pro frame that connects to the end of the shock shaft
    Oct 2011
    No, link is original from pro frame. I've swapped only RP23S, nothing else. Colors on this photos are not great. RP23S is brand new from specialized, I've good friends in LBS that helped a lot... I'll make more detailed photo of linkage and RP32s for you.
    Jan 2011
    So when you dumped all the air and checked the full motion of the shock you had no fouling of the tyre against the seat tube? What did the shock cost you? Very keen to see this pan out for my '11 sworks stumpy. I have the brain and would love to swap for the rp23 or at least have backup prepared.
    Oct 2011
    There will be not tire contact with seat tube but there will be crash of upper part of rear triangle if so. You can trust me, this doesn't happen with SJ 2012 EVO shock. It has only cca. 1.5mm more travel than original shock and there is enough free air for full stroke movement. BTW, this was first thing I checked after RP23S installation. I've paid 400EUR for it.
    Jan 2011
    Awesome thanks for the info, I know the brain shock can have the brain part removed and sealed off by a grub screw. Just wondering if I did that and found a cheap off the shelf rp23 not the specialized version, if I could swap the brain shocks shaft onto the new rp23. Obviously you would lose the kashima shaft but gain the feel of all the rp23 settings.
    Reputation: ktm520's Avatar
    Don't know if this has already been mentioned, but the damper body of the Triad can be swapped into a new RP/CTD shock. I did this for my dad with excellent results.
    Jan 2011
    Yeah mr lynch on here did it also. I'm wondering if the Brain shock shaft is same as triad when you remove the brain. I sold my 2011 stumpy fsr comp with triad and now have 2011 sworks with brain.
    Couldn't say, I've never had my hands on a brain shock. I know the Epic's use a silly small diameter damper body. The diameter of the shaft wouldn't matter as you would use all the guts from the new shock. The damper body diameter (slides in and out of the air can) is what is important. I believe the damper body of a standard RP/CTD is 1.06". If the same, chances are it would work. The next question would be the thread size of the fitting for the remote reservoir and whether or not it can be replaced with pellet and a plug.
    Jan 2011
    Quote Originally Posted by ktm520 View Post
    The mechanic at my local spesh dealer said they have removed the brain for a few customers and sealed the shaft at that screw. They were left with rebound adjustment only along with air pressure.
    Oct 2014
    Hey guys. I have a 2010 Stumpjumper fsr comp 29er. I blew out the fox triad. I found a shock that was on a 2013 Specialized stumpy evo 26ers. The dimensions are 194mm by 51mm. The triad dimensions are 200mm by 45.72(1.8inches). Will it fit? If so how will it effect the geometry?
    Reputation: trailbildr's Avatar
    Dec 2004
    You can get newly-rebuilt Triad rear shocks from your local Spec'd dealer to get rid of the Brain. I've been selling a lot of those lately on 2010 bikes. Bye bye Brain, hello 3 settings of compression damping. Just a few bucks more than a total rebuild.
    mk
    TrailWerks Cyclery
    TrailWerks Suspension Service
    trailwerkssuspension.com
    trailwerkscyclery.com
    Oct 2014
    I have no brain on mine and would prefer not to rebuild triad. Would the 194x51mm fit ?
