Results 1 to 6 of 6
    Sep 2012
    Fox rear shock lockout
    I am looking at a 2012 Fuel 7 with a fox rear shock. When I turned the lever to lockout it would still move. I thought that it would stop all movement in the shock. Am I wrong in this assumption or is the shock defective?
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    Re: Fox rear shock lockout
    Fox makes a lot of rear shocks. Most without a lock out. What model is it?
    If it is the RP 2 that they show on their website then it has no lock out.
    Quote Originally Posted by textatt View Post
    If the shock is an DRCV RP2 then it doesn't have a lockout. It has Propedal which is a form of LSC that increases dampning to a set level based on the shock's tune.
    Sep 2012
    Quote Originally Posted by keen View Post
    Fox Performance Series Float RP-2 w/DRCV, ProPedal, rebound; 7.252.0″, tuned by Trek in California
    Ok, that makes sense keen because it did stiffen up with the flip of the switch. What does LSC stand for.
    LSC - low speed compression.
    Sep 2012
    Ok, thanks for the information. It certainly eased my mind as I thought the shock was bad. And that comes already set from the factory so I will not have any control over it?
  1. Replies: 0
    Last Post: 04-02-2013, 04:08 PM
  2. Fuel EX8 rear shock lockout
    By stygz1 in forum Trek
    Last Post: 10-02-2012, 05:35 PM
  3. Rear shock lockout question
    By acer66 in forum Shocks and Suspension
    Last Post: 09-30-2012, 02:07 PM
  4. Replies: 4
    Last Post: 08-22-2011, 04:30 AM
  5. Rear Shock with Lockout - Options?
    By Kerosinek in forum Downhill - Freeride
    Last Post: 01-18-2011, 12:06 PM
