    Fox Polymer mounting hardware on a Marz Roco LO
    Hi all, I just got a new rear shock for my SC Nickel. It's a Marz Roco LO. My old shock is a 2012/2013 Fox Float RL with the polymer mounting hardware.
    I've heard conflicting opinions if the hardware is transferable. Has anyone had experience doing this? What I found is I can press (with a rubber mallet) the mounting pin from the Fox through the Roco eye but with only the black polymer spacer (the flange bushings will not fit inside the smaller I.D. of the Roco), there is still some exposed mounting pin. If I had TWO black polymers for each side, then I'd be ok I think...
    Any ideas or do I just need to suck it up and order the Marz mounting kit? Thanks a billion!!
    Fox mounting hardware I am referring to:
    moaaar shimz
    Reputation: tacubaya's Avatar
    Yes you should be able to use that mounting system. You need to remove the DU/DP bushing from the Roco in order to install the flange bushings.
    Quote Originally Posted by tacubaya View Post
    Ahhh. I was afraid to do that. How do you remove it?
    moaaar shimz
    With a bushing extraction/install tool.
  1. Replies: 20
    Last Post: 05-11-2013, 05:48 AM
  2. Marz Roco WC Air settings
    By retrofred in forum Shocks and Suspension
    Last Post: 02-07-2013, 08:36 PM
  3. Marz Roco WC. Any changes since '08
    By dustyduke22 in forum Shocks and Suspension
    Last Post: 06-25-2012, 10:29 PM
  4. Replies: 4
    Last Post: 03-23-2012, 01:15 PM
  5. Dhx air hardware used for a roco tstr shock?
    By Mtbags in forum Downhill - Freeride
    Last Post: 05-25-2011, 10:38 AM
