    bike tester
    Reputation: syl3's Avatar
    Fox Float RPL rebuild
    I have an RPL that is blocked on the locked out position... anyone know where i can purchase a rebuild kit for the hydraulic part of the shock?
    I already did the air part a couple months ago and it was fairly simple.
    Thanks a bunch
    bike tester
    reading a bit more it turns out that a lot of rpl/triad shocks are affected by the stuck down thing.
    just to make things clear, my shock is not stuck down, it is fully extended, and the lever is blocked in the lockout position too.
    any ideas, suggestions? is this a dyi type of repair?
    bike tester
    bump
    Reputation: honourablegeorge's Avatar
    Seals are the only user-serviceable bits on fox, tbh. You need to take it to a dealer.
