Results 1 to 5 of 5
    Reputation: mcandy's Avatar
    fox float rp3 schrader valve
    are there replacements available and can a reasonably competent home mechanic replace? Mine exploded today. schrader valve exited the shock body, very hostile. have yet to find the valve. Fox was closed today so figured I would try to get an idea here so I can relax. First day off in a long time friday and I am antsy to ride. hoping I can somewhat easily replace the valve and carry on without having to ship back to fox. thanks
    Life Is Short
    Reputation: fatcat's Avatar
    Mar 2006
    call these guys 2morrow, they sweat a lot of the small stuff. They had spacers for a Fox shock so go figure.
    The Path Bike Shop - Home
    Get a standard automotive shrader valve from an auto parts store.
    HAHA PWN
    Reputation: Vhom's Avatar
    I had the same issue and use a old Schrader valve from old bike tube. Been over a year and no issues.
    Mar 2005
    Are the threads still ok inside the valve? Was it just the core that blew out? If it is just the valve core then any old tube you have will have a core that you can steal. You will need a valve core tool which is cheap and available at any auto parts store. If the threads are damaged then it will require a bit more work.
