Results 1 to 9 of 9
    Dec 2010
    Fox Float RP2 nitrogen refill valve modification.
    Hi All,
    I am planning to modify the nitrogen refill valve with a schrader valve
    Shown as Number 1
    with something like this.
    which is available from here.
    Fox Racing Shox Schrader Valve Assembly 802-00-012 : Amazon.com : Automotive
    the question is, does the schrader valve thread compatible with the fox float thread?? Do you know any other better alternative???
    Thanks for your help
    Save Jesus
    Reputation: beanbag's Avatar
    How to you plan to remove the air can?
    Feb 2010
    You just need to remove the valve and repressurize the IFP once you've done the air can service. There's some good info over here.
    Reputation: rustybkr's Avatar
    Re: Fox Float RP2 nitrogen refill valve modification.
    Quote Originally Posted by TigWorld View Post
    Wow, thanks for posting that link, I'm gonna poke around some more over there. That site seems to have :thumbup:
    I've just ordered the valve. I've been searching for this for a while. Thanks
    Dec 2010
    Really big thanks from me. Info that I have been looking for
    Jun 2013
    Hi I did a similar modification on my coil DHX 5.0 using the same fox schrader valve, the threads do not match the thread on the nitrogen valve so I had to purchase a schrader tap for the new valve to fit, once you have the hole re-tapped you will most likely need some sort of sealer to put on the threads, I used a high pressure gas fitter's sealant:
    Jet Lube V2 Plus Joint Compound JETLUBE, JETLUBE
    shock now works a treat and is easy to service at home without having to worry about getting it nitrogen charged, now i can simply use my shock pump!
    Nov 2013
    You should find a big difference between filling with nitrogen and air, especially after the you have ridden for a while and the gas heats up.
    Any thoughts on this?
    Air is 80% nitrogen anyway, doesn't matter. Bottled nitrogen would be very dry and filtered (both good things). IFP chamber is only used as a relief for the oil during shock compression (other wise shock would be in hydraulic lock). Nitrogen is a little closer to a "perfect gas"; it still expands during heating, and shrinks during cooling.
  1. Advice needed for Fox Float RP23 Nitrogen Valve
    By Matt Scales in forum Shocks and Suspension
    Last Post: 09-28-2012, 09:23 AM
  2. Fox Float RP23 - what pressure in nitrogen chamber?
    By painless in forum Shocks and Suspension
    Last Post: 09-26-2012, 11:08 AM
  3. fox float rp3 schrader valve
    By mcandy in forum Shocks and Suspension
    Last Post: 05-16-2012, 07:53 PM
  4. Replies: 5
    Last Post: 01-31-2011, 03:08 PM
  5. Air valve- Monarch vs Float RP23
    By Flboy in forum Shocks and Suspension
    Last Post: 01-21-2011, 03:53 PM
Members who have read this thread: 10
