Results 1 to 3 of 3
    Feb 2013
    Fox F120 or or Rockshox Recon Gold TK SL
    Just received a BMC SF02 2011 with Fox F120's fitted.
    I also have some RockShox Recon Gold TK SL's on the way.
    I don't know enough about forks to know which is best. Both are 120mm, so suited to the bike.
    Reputation: Kiwiplague's Avatar
    Stick with the Fox's, much better damper than the Recon. Fox has a shimmed rebound damper whereas the Recon has a very basic port orifice. (shims are good, ports are bad).
    I don't crash, I just have slightly uncontrolled dismounts!
    Feb 2013
    I like that advice, means I don't have to swap them around.
    Thanks.
