    Fox DHX 4.0 Air rebound knob Jammed/Stuck
    OK, i hadn't moved this since having the air sleeve serviced. I figured i wanted two more clicks of rebound, but i could not move it.
    The only way i can turn the red rebound knob, clockwise or counter, is to jam an allen wrench in there and push relatively hard. A snapping click occurs every 7th click, the rest move somewhat smooth, although there is some grinding in there that is typical of dirt being in with the knob/gear.
    Any suggestions? Is my rebound knob really messed up or is it just gunked up?
    Anyone have similar issues?
    bump
    Yes, it gets dirt in there and causes it to bind. I have used a spray bottle and sprayed it with water to wash out the sand. Then a small allen key to move it.
    meow meow
    Reputation: b-kul's Avatar
    happened to mine too. did what canuck did and it is all set now.
  1. What the F@(k Fox f120 RL Rebound Knob Stuck
    By chtorres2 in forum Shocks and Suspension
    Last Post: 05-08-2012, 05:38 AM
  2. Marzocchi 66 ATA rebound knob stuck?
    By creyc in forum Shocks and Suspension
    Last Post: 06-11-2011, 09:02 PM
  3. TALAS 32 rebound knob is stuck
    By ChubbyBiker in forum Shocks and Suspension
    Last Post: 05-26-2009, 02:54 PM
  4. Rebound Knob on Fox Float RL Stuck
    By bxb03a in forum Shocks and Suspension
    Last Post: 02-15-2007, 12:02 AM
  5. Stuck rebound knob after rebuild
    By optimator in forum Shocks and Suspension
    Last Post: 05-04-2006, 10:58 PM
