Results 1 to 10 of 10
    Reputation: knobby1's Avatar
    Fox CTD shock leaking oil
    I have a 2013 Fox CTD shock that is leaking oil. The shock holds air and the dampening works fine, but it continues to leak the green fox fluid.
    I had the bike to my LBS where I purchased the bike. They thought maybe something got into the seal so they took the shock off cleaned it and refilled. It seemed to be okay for a ride, but it is now pissing out oil again.
    The shock is less than 2 months old and under warranty. I was told that it would be 2-3 weeks if I sent it out to Fox for warranty repair. WTF!!
    Any simple fix or do I need to send it to Fox?
    Reputation: ktm520's Avatar
    where exactly is it leaking?
    Reputation: ghettocop's Avatar
    Send it to Fox Service yourself, not through the LBS. They will do the warranty work in 6-8 days.
    Quote Originally Posted by ktm520 View Post
    Running down rear shock stanchion to the point it is dripping on frame.
    How many times have you ridden it since they did the can service? It's normal for it puke float fluid between the can and stanchion for awhile after a can service. It will keep puking until it pushes all of the float fluid out of the air can. Sounds like they may have put too much oil in the can. It only needs a couple cc's, not the whole 5cc in float blister pack. If it holds air through a ride, I wouldn't worry about it. The damper fluid is red in color.
    I've taken 3 rides for a total of approx. 50 miles not including some lift served riding I did the other day.
    I think they put the recommended 5cc in the shock. Like I said, the shock holds air and the dampening works. My main concern was damaging the shock, when all the Fox fluid leaks out.
    Quote Originally Posted by knobby1 View Post
    I'd have to double check, but 5cc is way too much. I believe it is only 2cc for Fox and RS recommends less than 1cc. IME, 1cc is plenty to keep things smooth for 50hrs. It doesn't hurt anything to put in more, but it will just pump it out in short order. Sounds like everything is normal to me. Keep any eye on your pressure. If it starts leaking down through the ride, then I'd be concerned.
    Reputation: SycoCell121's Avatar
    I had this exact issue on my 2012. LBS sent it to fox once...got it back, started leaking again. Sent it back out, got it back in 2 weeks and has been working since - 2 months. Fingers crossed. Just make fox do it!
    D_K
    D_K is offline
    Dec 2010
    This is what my LBS told me as well. I have a 2013 CTD Kashima rear shock and it weeps a noticeable amount of fluid but they said it's just what they do until their seals get settled / dried out a little bit and the chamber gets cleared out. I didn't buy the bike from them and was willing to pay them to rip it apart, so it's not like they had a reason to BS me.
    Thanks for the replies! Since the shock is working fine, I think I will keep an eye on things and keep riding.
  1. Help front shock leaking?
    By robmoto in forum General Discussion
    Last Post: 06-17-2013, 06:18 PM
  2. Marzocchi TST2 shock help Leaking oil
    By excaliber in forum Beginner's Corner
    Last Post: 05-21-2012, 01:18 PM
  3. shock leaking after one ride and month of sitting??
    By DanLeeGT in forum Shocks and Suspension
    Last Post: 03-20-2012, 09:02 AM
  4. help my shock it's leaking oil...
    By carspidey in forum Beginner's Corner
    Last Post: 10-25-2011, 08:18 AM
  5. X-post from Shock/Suspension - RST M29 leaking?
    By gregnash in forum 29er Bikes
    Last Post: 07-01-2011, 08:10 AM
Members who have read this thread: 11
