Results 1 to 31 of 31
    Reputation: ktm520's Avatar
    Fox CTD shock 2013 issues
    Bought a SB95 frame back in Nov that came with a 2013 CTD trail adjust shock on it. At 10hrs, I noticed it had sucked a very small amount of air into the damper, audible but no noticeable loss in damping. At 25 hrs, it was getting worst and I could then feel the lossin in damping with the lean on the seat test. Finally sent it off for warranty rebuild at 35hrs. Fox replaced the shaft seal, pp spring, small pp shims, and the air can seals.
    2 weeks later, got it back and after the first 1hr of trail time, I could already hear air in the oil again. Now, at a whopping 4hrs, I can feel a loss in damping. To say I'm frustrated is an understatment at best.
    This is my first experience with a Fox boost valve shock. What gives here? Am I just extremely unlucky or are these shock notorious for sucking air due to the lower IFP pressures? It's a 175 bv tune. I've been running 155psi in the spring and ride in Descend mode 99% of the time.
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    I don't have an answer to your question, but what are the signs/symptoms of sucking air into the damper?
    Dec 2010
    Hi,
    I have issue with my 2013 Fox Float CTD Evolution 8.5x2.5 shock that has ID CCZ9, compression tune is L and climb tune is F, it came on Santa Cruz Heckler frame and has no Boost valve or trial adjust.
    My first impression from the first ride that in climb mode the shock is completely closed and a 6 frame climbing like a hard tail.
    I take the bike to our local Fox service center and asked them if any option or calibration available to do it little more plushy at climb mode, and I get the answer yes and they can reduce some pressure of Nitrogen gas from the shock to get it work plusher in climb mode, for my mistake I agreed to this and now I have some issue with it.
    When I descending on fast downhill tracks with some jumps and technical areas with small bumps I hear a very strong metallic noise like air hummer strike from a shock, its sounds at the beginning of a suspension or like very fast rebound I dont know how to explain this.
    I already take a shock two additional times to the service center and they try to play with the pressure of nitrogen gas, increase or decrease and nothing, I ask them also what exact pressure value need to be placed in this shock 175psi/200psi or maybe 225psi and they dont know to answer me.
    May be some one here on MTBR can advise, what exact values of nitrogen charge need to be put inside a shock for optimal performance on my bike.
    vadimn, the "boost valve tune" should be labeled on the air can of your shock. That number is the ifp pressure. Do you know where the guys at Fox set your ifp pressure when you asked them to soften it? I don't know what the acceptable range is for a inline shock, but most I've seen are between 150 and 200.
    Just a theory, but if they went low on the ifp pressure, the noise you are hearing could be the boost valve slamming open during hsc.
    Before you changed the ifp pressure, did you try using trail mode? You are really comprising the overall shock performance if you lower the ifp trying to get plushness in climb mode.
    Dec 2010
    ktm520, thanks for reply.
    Evolution Series line of the Fox Float CTD Shocks has no boost valve, it some cheaper (OEM) version, Boost Valve only available on Factory Series shocks.
    My shock worked fine in Trial and also Descend modes before they play with nitrogen pressure. Now in both of modes I can hear this metal noise, its looks like very fast rebound or some think like this but I have no idea what is this and also guys from Fox have no idea too.
    My bad, I missed that it is an Evolution shock. In that case, changing the ifp pressure is not what you want and it will make very little difference. The ifp should be around 400psi for your shock regardless of tune. The new CTD's are basically the same internally as an RP with a different lsc adjuster.
    Did you make sure that the shock eyelet bolts are tight?
    G_g
    G_g is offline
    Quote Originally Posted by ktm520 View Post
    I am having the same problem, shock has under 25hrs of riding (bought at end of February). I've had the same problem on a DHX Air. I'll send it to warranty, to see if it gets better. I wish we could change the IFP pressure like in the Rock Shox Monarch...
    Keith Scott: If you want to go mountain biking, then throw a leg over a new Banshee and the bike will do the talking
    Vorsprung Suspension
    Reputation: Steve VS's Avatar
    Oct 2012
    Quote Originally Posted by vadimn View Post
    It sounds like what you are experiencing is cavitation on hard hits. Cavitation is caused by the pressure required to force oil through the piston fast enough to fill the space behind it, being lower than the actual pressure in front of the piston (which is determined by the IFP pressure). It often feels like a jarring/spiking sensation followed by a brief moment of zero rebound damping, often followed by another "slapping" sensation as the piston hits the oil behind it during the rebound stroke. This all happens VERY quickly and can easily feel like a single jarring event.
    This is specifically caused by an IFP pressure that is too low - it should be 400psi. The reason Boost Valve Floats can run lower pressure in the IFP is because the BV will open fully once the pressure behind it drops sufficiently (rather than requiring the pressure in front of it to climb hugely), which means cavitation is far less of an issue - this does not happen in the same manner with shims. All the harshness in the climb mode (which realistically is a complete lockout) is to do with the valving, not the IFP pressure - the options available to you are basically either making more use of the Trail mode, or getting the thing revalved.
    VorsprungSuspension.com - fully engineered suspension retuning & servicing in Whistler, BC.
    Dec 2010
    Thanks Steve,
    We actually rebuild a shock yesterday with new seals and 26Bar of IFP pressure.
    I am going to a test ride and will post here later.
    I have a non Boast Valve CTD shock which I bought when they first came out last year. Didn't put a lot of time on it last year.
    On today's ride, it started making the slurp noise and would occasionally feel like it would fall through the travel.
    Now to decide whether to send it to Fox for warranty or off to Push
    Dec 2010
    Ok guys,
    After we rebuild a shock and fit 26bar in IFP, I still have more or less the same issue, may be less then more from a beginning but I still can hear kind of jarring event that Steve talking about it.
    My question is - is it possible to put 400PSI? Guys from Fox Service Center thinking that I am sick / crazy person...
    Yes, that specification is directly from Fox. I think you may want to find a new service center. 26bar=377psi, so you weren't to far from 400.
    Dec 2010
    Yeah, I know, all of us having issues and returns to this service center for more that 2,3,4 and some times 5 times to solve issue or tuning after shock service.
    This service center located 10 to 30 minutes in car from us, we have another service center much better from this but it located 2 hours driving from my location.
    So, better to buy some CCDB Air or Rock Shox .
    DFMBA.org
    Reputation: MTBeing's Avatar
    I'm gonna chime in here because I have a separate issue but want to keep this thread alive too. I have a year-old (2013) Giant Trance X29 with the Boostvalve CTD shock. About 1 month after owning the bike the shock leaked oil more than normal out the seals. Lbs sent it off and I got the bike back 2 weeks later with a shock that looked to have an extensive rebuild by Fox, according to the work order that accompanied it. Fox claimed in the w/o that the oil disbursement was 'normal' but that they serviced it anyways. I know they did something with the CTD lever because it was crisp-acting when I got it back. Before that, it was kinda loose in the C or D modes.
    Fast-forward about 1 year and the shock has no discernible actuation feel in C,T, or D. Pedal bob is pretty bad and I have replaced the seals myself, thinking this was the cause. I'd like to think a simple seal replacement could not have caused this CTD to malfunction but the shock felt great after I serviced the seals. Now I'm getting pedal-bob and the a$$ end of the bike feels like it's dragging. I also have the air pressure set to provide normal sag (about 25%) and the rebound seems to be working ok.
    I'm looking for suggestions here. The shock is out of warranty but I'm divided between sending it to PUSH or sending it back to Fox and risking them just giving it a lick and a promise. Right now I have very little confidence in Fox.
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
    Reputation: PUSHIND's Avatar
    Quote Originally Posted by MTBeing View Post
    The CTD shocks use a pressure sensitive piston that relies on the nitrogen gas to produce compression damping, but a shimmed system on rebound. Over time you get both a break down of the damping fluid as well as a drop in the gas pressure in the shock which cause the shock to develop a softer feel on the compression stroke. Basically, what you're describing is normal and a sign that you're in need of service.
    If you are considering us, we have a pretty great deal going through the end of this month! And hey, maybe you'll be the lucky winner and can get yourself setup with a spare shock for your bike!
    Push Industries - Click Here for Winter Special!
    Darren
    As Darren stated above, your shock just needs a damper service. You have ridden the shock for a year, and this is completely normal. It is not Fox's fault. They specify that damper service should be done every 100hrs of riding, or once a year. You should just send it to Push.
    DFMBA.org
    Looks like it's PUSH. Thanks Darren and Matty. You're right on with the squishy feeling.
    We at Avalanche Suspension have a solution to the CTD/RP23 Float shocks. We remove the Boost Valve and convert it to a speed sensitive damper (SSD). This is done by converting the Boost Valve system to a valving shimmed compression system. This allows us to reduce the pressure on the IFP to normal shock pressures increasing the life of the oil and nitrogen charge. The SSD system provides for better performance on high speed square edged hits and can be custom tuned for any linkage curve or rider preference. We have also modified the internal compression adjuster system to our high speed blow-off (HSB) system, The low speed circuit is converted to our HSB system, this allows for increased low speed compression that blows off on small bumps and creates high speed threshold adjustment without harshness in the high speed circuit, we can tune this up or down depending on the adjustment range you are looking for.
    Check it out here:Float CTD and RP23 SSD Modifications
    Thanks Craig. I revlaved the rebound in the ctd (big improvement) and played with different ifp settings, but it still spikes on square edge, which I can't tune out of it without a higher flow piston. I've been meaning to look and see what you all have to offer for the float shocks. Right now, I'm torn between getting a Monarch RT or + and revalving it myself, or sending off the ctd for a Avalanche/Push tune.
    Can you expound a little more on the HSB system? Doesn't sound much different than the varying spring loaded poppet valve Fox already uses. What exactly do you mean by "high speed threshold adjustment"? I like the idea of increased lsc without increased harshness but isn't that kind of the holy grail of offroad suspension?
    The spikes will smooth out if you remove the boost valve and replace it with shims, then the IFP settings will not be critical and a standard pressure will work. Lets just say we have found the holy grail of suspension! No, basically what everyone wants their suspension to feel like is to have low speed compression that holds the shock up and is plush on small bumps, not bottom and slice through squared edged bumps. If you add a valve the stays closed long enough to provide low speed compression for pedaling(threshold), but has the ability to open a predetermined amount (float) and can blow-off at a controlled rate(high speed blow-off, HSB) and then the shim stack can then blend in to control the entire stroke, then I guess this would be the holy grail. We try to accomplish this by using one of 3 different rate springs that are the proper length to determine the correct preload, rate of blow-off, float (free length to solid height) to get the desired affects. So yes it is sort of how the Fox system works we just re-engineered it to do what we want it to do.
    We have a similar system we use in our fork cartridge system described here:Floating Valving Assisted Threshhold High Speed Blow-off System
    Gotcha. My gears were spinning off in a more elaborate direction that was trying to envision how you would completely redesign that circuit. I wouldn't have thought that the bleed circuit would flow enough oil to affect hsc but it sounds like it's more for controlling the transition to the shim stack. I had a looked for a source for the small poppet spring but it wasn't cost effective for small quantities.
    I just read your FAQ page. Very informative. I was under the impression that the stock piston wouldn't flow enough oil. Thanks for the feedback.
    Reputation: mullen119's Avatar
    Subscribed! I want to keep an eye on where this thread is headed. The last few posts are very interesting.
    Also, Craig, you need to post on here more.
    Quote Originally Posted by mullen119 View Post
    I will as needed, I do follow these forums very closely.
    10-4. If you have any questions, feel free to drop us an email or phone call.
    I think it's important to point out that the stock FOX Boost Valve from the factory is speed sensitive. For that matter, every MTB fork damper and rear shock is. What makes the stock FOX Boost Valve piston assembly unique is that it provides a secondary component that is also position sensitive in addition to the speed sensitivity.
    Darren
    Quote Originally Posted by PUSHIND View Post
    Darren
    Yes, but is it really speed sensitive enough? oil is oil now, I guess!
    Quote Originally Posted by crseekins View Post
    We This allows us to reduce the pressure on the IFP to normal shock pressures increasing the life of the oil and nitrogen charge.
    Just for curiosities sake, what is considered "normal" shock pressures? I have seen IFP pressures listed as low as 125psi up to 500psi. So what would a normal pressure be? 200-250psi?
    The minimum pressure for a typical shimmed speed sensitive shock to prevent cavitation is 140 psi, but does depend on shaft volume to reservoir volume, we typically charge most of our shocks to 160 psi. Some more heavier damped or higher air can pressure shocks we will charge to 225 psi.
    Awesome, Thanks for the info!
    I'm not sure what this means. All current MTB forks and shocks are speed sensitive....that's how the damping force is measured. I'm assuming what you mean is that the compression damping isn't "progressive" enough? In which case, progressive force curves don't always compliment MTB frame designs.
    Darren
    Feb 2010
    Can you please clarify.
    When you say "typical shimmed speed sensitive shock" do you mean the shock with the shimmed piston like older, non-BoostValve RP23 models were? Or is it something else? I looked at the pictures on your site and it seemed like you are talking about ordinary shimmed piston.
    Old Fox documents from 2009 specify IFP pressure 400 PSI for ordinary shimmed Float RP shocks. For 2013 Evolution series forks (all of them are without Boost Valve) and for Performance and Factory series forks without Boost Valve Fox specifies 500 PSI.
    This is confusing me. You say that "normal" pressure is 160 PSI, but Fox seems to think that it is 500 PSI.
    Hej guys,
    this seems to be the thread where a lot of boostvalve knowledge is around.
    I am on a v2 Banshee Spitfire and a Float CTD which really impressed me so far! Didnt have too much problems with fading even doing 800 meters decents in the alps and in general is doing a good job of controlling the KS Links impressive 140mm of travel.
    But since it is in need of a bigger service i am thinking about rebuilding this thing a bit, towards more agressive riding and less comfort.
    Ive been studying a lot of cutaway pictures of a boostvalve shock, boostvalve/shimstack theory and damping curves and trying to bring this all together.
    I am far from understanding every bit of it, especially how to mate a shock to a frames leverage ratio curve and its axle path...
    Fox CTD shock 2013 issues-banshee-spitfire-v2-production-2013-2013_levratio.jpg
    But this is not a good place to start anyways.
    So the point of this boostvalve design is to get a digressive curve with supple lowspeeds up to a certain velocity and shaft position and then to transit into its highspeed compression circuit.
    Of course this curve is simplified but ill use this as a reference for my wishes..
    On the CTDs piston the boostvalve is mated to two shimstacks on all the cutaways ive seen. The Boostvalve seems to be preloaded by oil (IFP) pressure, hence closing the bigger ports on the piston. Here blue:
    As long as the BV is closed, oil will flow through the lowspeed circuit only..
    When the shaft is moving at a higher velocity the oil is forcing its way through the blue ports, lifting the upper BV half which in turn is lifting this big shim sitting on top of it.
    Some kind of transition to a hsc circuit is going on? The blue ports are only designed to lift the BV and not to transport the majority of the oil?
    With the BV being position sensitive this means the LSC part of the damping curve is becoming smaller the deeper the shock sits in its travel?
    The bigger the N2 Volume behind the IFP the later the inflection point in the digressive curve is gonna be and the longer LSC is playing a role (shaft position)? (bigger volume being more sensitive to compression by the main piston)
    The higher the pressure in the IFP chamber the higher the inflection point is gonna sit..
    The HSC shimstack adds its damping force at the inflection point, defines the slope of the curve up to the end of the shocks stroke?
    This BV design is quite a handful but i am eager to try a few things out, but first id love to set this theory straight, any explanation and thoughts are welcome.
    My first modification is going to be a reduction of HSR, to be able to increase LSR without the bike packing up over fast medium sized hits..which is my main critique so far.
    At this point i plan to change suspension fluid to spectro golden light, wich has a similar Cst at 40C but is much more stable up to 100C than anything else.
    I hope this is readable, since this is not my mother tongue
    cheers,
    Lukas
  1. Mukluk2 front shifting issues-2013
    By builder in forum Fat bikes
    Last Post: 01-23-2013, 10:32 AM
  2. First-gen Scalpel shock issues
    By bassteban in forum Cannondale
    Last Post: 04-11-2012, 11:43 AM
  3. 02 RFX rear shock issues
    By tmarkos in forum Turner
    Last Post: 02-28-2012, 03:04 PM
  4. Issues with RT3 shock on El Guapo
    By Penny in forum Titus
    Last Post: 01-14-2012, 10:54 AM
  5. rear shock issues
    By rwrc in forum Clydesdales/Tall Riders
    Last Post: 03-17-2011, 07:00 PM
Members who have read this thread: 14
