• 07-19-2012
    kosmo
    Fox A/C Dimension Difference
    Can somebody tell me how much A/C I will gain on my 29er by switching from an F32 to an F34 chassis? Assume that travel will stay constant, at 110.
    I'm sure this info is available in several places, but I struck out on the F34 with my feeble searching skills, so thanks (F32 looks like 511 mm)!
  • 07-19-2012
    rockyuphill
    Here's the F34 29er spec, the shortest travel 2013 F34 seems to be 120mm, and 130mm in the 2012 model, so you'd have to add spacers to drop the travel.
    http://service.foxracingshox.com/con..._SPEC_RevB.pdf
    here's the F32 29er spec for 44mm and 51mm rake forks
    They are all listed under Product Specifications in the left side navigation here
    Fox WebHelp
  • 07-19-2012
    kosmo
    Thanks much for the links. Looks like I will gain about 12 mm. I can live with that. Not stoked about it, but it should basically "disappear" after a couple of rides.
