    I am a Nomad
    Reputation: tp806's Avatar
    Nov 2008
    Fox 36 Float RC2/Manitou Evolver ISX-6 OR Marzocchi 66 RV ETA/Fox DHX 5.0
    People, I need your help and educated opinions on this matter of changing the suspension on my 2009 SC Nomad all-mountain setup.
    I know actually what this boils down to, is the air vs. coil debate, but I am about to pull the trigger on this clearance deal on my LBS for this air sprung combo of 2009 Fox 36 Float RC2/Manitou Evolver ISX-6 for under $1000 fitted and I want any last moment heads up from other users.
    Currently my Nomad has a 2007 Marzocchi 66 RV ETA/2009 Fox DHX 5.0 coil suspension combo, which I am pretty happy about in general except from the weight (about 35lbs.) and my riding is 60% AM - 40% FR.
    But this offer prize-wise and weight-wise is too good to miss, so please let me know what you think?
    Have you used such a setup for all-mountain riding and more specifically how do they compare:
    - 2009 Fox 36 Float RC2 vs. 2007 Marzocchi 66 RV ETA (both 160mm)
    - 2009 Manitou Evolver ISX-6 vs. 2009 Fox DHX 5.0 coil
    I know it's like comparing apples with oranges (air sprung vs. coil sprung) but nowadays, with the development and improvements in suspension engineer and materials, performance-wise both types are separated by a very thin line when used for the same kind of riding.
    Also what about maintenance, does the Fox 36 Float need constant care?
    Do I pull the trigger or not?
    Change from full coil to full air or not, is it worth it, or stick to coil and have more piece of mind?
    Reputation: Vespasianus's Avatar
    Best bet would be to ask TNC. I think he runs a similar set-up.
    I am a Nomad
    Nov 2008
    Quote Originally Posted by Vespasianus
    By all means, much appreciate it if TNC could chime in on this today.
    Reputation: mattsavage's Avatar
    Sep 2003
    Go the air route! You'll save pounds off your bike and definately not lose any piece of mind! The Evolver I had on my High Octane was every bit as good as the coil it replaced and very reliable!
    "I wrote a hit play! What have you ever done?!"
    Have Ashtray, Will Travel....
