Results 1 to 3 of 3
    Reputation: PhaseSpace168's Avatar
    Sep 2012
    Fox 36 Fit RC2 oil seeping through the air valve.
    title.
    Could this mean that the Fit cartridge is blown, or is this normal. It doesn't seem to be behaving any differently. Is this an issue, if so can i ignore it until service time? Its only seeped out a tiny bit. Fork is a 2013 160mm RC2
    Thanks.
    Dec 2009
    The fit cartridge is in the other leg. It will be lub oil from above the air piston. It's normal for a bit that has coated the valve to come out when you relaese air pressure.
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    It's "float fluid". ie. that thick blue oil used to lube and help seal the air chamber. Perfectly normal for a tiny bit to spew out of the air valve.
    2011 Yeti 575 - Fox Float 36 RC2 160 - 31.5 lbs
  1. Replies: 5
    Last Post: 03-25-2013, 09:51 AM
  2. tubeless tire starts seeping fluid - trash it or ride it?
    By fitnessgeek in forum 29er Components
    Last Post: 02-20-2013, 08:34 AM
  3. Replies: 13
    Last Post: 11-26-2012, 11:22 PM
  4. Replies: 14
    Last Post: 06-21-2012, 06:59 AM
  5. RS Domain 302, seeping oil
    By istandalone in forum Shocks and Suspension
    Last Post: 04-16-2011, 08:01 AM
