Results 1 to 3 of 3
    Jul 2014
    Bonking ... not feelin' well Fox 34 130mm 2013 sensitivity problems
    Hello there
    i have a set of 2013 fox 34 float 130mm ctd 29er forks which are kashima coated
    they just don't seem to have any where near the same small bump sensitivity as my 2009 rockshox recon solo air forks
    Neither of the forks bottom out and they are set at their correct sag weight
    I've tried just lower ring the air pressure but then I bottom out
    i do weigh 14 stone, I don't know if that would change anything atall
    I just don't see how they can be such an expensive fork yet not feel anywhere as good as a cheap 2009 one
    If just like them to both feel the same!
    any thoughts on what I can do would be greatly appreciated
    many thanks
    Chris
    Reputation: 11053's Avatar
    Are you adhering to Fox's scheduled service intervals?
    Number one thing to keep that fork performing optimally is not neglecting service.
    Switching to Fox 20wt Gold bath oil will make a noticeable difference.
    Reputation: reamer41's Avatar
    If you haven't done it yet, lift the fork wipers and add some lube, slide the wipers back in to place.
    It is part of the maintenance mentioned above. It's pretty easy and quick. If it's not done after a time you will think you have wooden forks.
    --Reamer
  1. Replies: 2
    Last Post: 05-15-2014, 01:26 PM
  2. Pike small bump sensitivity.
    By Lpcunity in forum Shocks and Suspension
    Last Post: 04-05-2014, 05:27 PM
  3. Bad small bump sensitivity on my Bronson- ?s
    By jmallory in forum Santa Cruz
    Last Post: 12-15-2013, 04:42 PM
  4. sensitivity of fork lockouts?
    By stonemxfan369 in forum General Discussion
    Last Post: 05-18-2013, 05:47 AM
  5. How to improve small bump sensitivity on a Lyrik DH?
    By baltik in forum Shocks and Suspension
    Last Post: 07-31-2012, 09:41 AM
