Results 1 to 5 of 5
    Fox 32 Float RL 100 travel adjust??
    Can a 2009 Fox 32 Float RL currently set at 100mm have its travel increased (i.e. internal spacers, etc.)?
    Jul 2003
    If it is...
    an aftermarket fork most likely. Standard (full) travel for the 09 Float was 140mm. If it's at 100mm there is likely a spacer or to installed to reduce the travel. If it is and OEM fork, it's not that certain, but still a good possibility. You'll have to open up the fork to be sure though.
    Good Dirt
    Pirate!!!
    Reputation: Captain Cobb's Avatar
    can we bring this up again I also have a 100mm rl32 float that could use an extra 10-20mm of travel.
    Same question - Just in reverse
    I've got a 2011 Fox FIT 29RLC with 100mm if travel and I'd like to take it down to 80mm. Is this possible?
    Thanks,
    Matt
    Extending travel:
    The only way to know for sure if you can extend your fork is to tear down the fork and see if you have any spacers installed which can removed, and see if the damper can extend far enough.
    Limiting travel:
    Yes, you can limit travel down by installing a spacer.
