Results 1 to 8 of 8
    New question here. Fox 32 Float CTD 29 vs. Manitou Marvel TS Air 29
    Hi all! I want to buy a new bike, and choose between this two:
    1) Cube LTD 29 SL
    2) Cube LTD 29 Pro
    Main difference is a suspension fork. Which is better:
    1) Fox 32 Float CTD 29 (Cube LTD 29 SL)
    2) Manitou Marvel TS Air 29 (Cube LTD 29 Pro)
    I will use it for soft cross-country, without extreme. I need better damper, and i heard, that Manitou has Absolute+ - best damper at this price.
    Second requirement - maintain as rarely as possible. Because i will travel on this bike about 500-700 km to uninhabited places and and I will be very limited in the tools and time.
    So, which fork will be better for my case?
    Reputation: El Cerveza's Avatar
    Nov 2012
    Sv: Fox 32 Float CTD 29 vs. Manitou Marvel TS Air 29
    Being a 29'er you could also go for a rigid fork...
    Sendt fra min GT-I9300 med Tapatalk2
    No, i will travel not only on asphalt and solid ground. Meadows, fields, marshes, forests - i think, suspension fork will be more convenient. But I don't know which of the two is better.
    Reputation: mullen119's Avatar
    Both are very good forks. The Manitou is more adjustable, the float is lighter. Honestly, you will be happy with either one.
    Exactly what does "more adjustable " mean??
    The manitou has a larger range of external compression adjustment and is easily internally adjustable to give a huge range of compression.
    The Manitou should require less frequent and less complicated maintenance.
    Thank you, guys!
  1. Manitou Marvel Pro Weight
    By Cary in forum Shocks and Suspension
    Last Post: 04-19-2014, 11:09 AM
  2. Manitou Marvel Pro Question
    By NS-NV in forum Shocks and Suspension
    Last Post: 12-20-2012, 06:15 PM
  3. Manitou Marvel Pro Suspension Fork Greensboro, NC
    By kdtanker in forum North & South Carolina
    Last Post: 12-05-2012, 03:14 AM
  4. HELP: Manitou Marvel Pro vs RS SID WC
    By kobayashi in forum Shocks and Suspension
    Last Post: 09-24-2012, 07:36 AM
  5. Manitou Marvel...
    By CSC in forum Shocks and Suspension
    Last Post: 09-06-2012, 08:53 PM
