Results 1 to 2 of 2
    Reputation: rearviewmirror's Avatar
    Good job! Fox 32 FLOAT 29 80mm FIT RLC to 100mm?
    Can the standard 2012 32 FLOAT 29 80 FIT RLC be converted to 100mm by removing the spacer, or are the stanchions of the 80mm shorter than the stock 100mm fork? I know the 100mm can be setup as 80mm, but I don't if the reverse is possible.
    Draft College Republicans
    Quote Originally Posted by rearviewmirror View Post
    I don't have first hand experience but maybe this helps.
    WebHelp
    Then go to : QuickTech: Forks
    Then :2002-2012 & 2013 80 - 120 FLOAT/F-Series Travel Adjust
